Old 05-28-2003, 01:02 PM
audiobob's Avatar
audiobob audiobob is offline
Default Re: Re:OS X/Pro Tools 6.x setup and general troubleshooting
As long as you selected "Install Mac OS 9 Drivers" when you formatted the drive.
Old 05-29-2003, 12:48 AM
tomcat tomcat is offline
I just upgraded and I had to reinitialize my drives for them to work well. My FW drives were formatted with OS9.2 "erase disk" and worked well in 5.3.1, but when I went to 6.01/X i was getting dae error 9131 80% of the time until I reformatted them in X. Do check the OS9 drver box when doing this and they should be good to go in 9 as well. I too am transitional. I installed x/6.01 on a fresh second internal drive, so I can always go back whenever I need to.
Good luck
tom
www.tompaul.com
Old 05-29-2003, 12:57 AM
ashdot ashdot is offline
Default Re:OS X/Pro Tools 6.x setup and general troubleshooting
I'm still in transition, trying to go back and forth between PT5.x in OS9 and PT6 in OSX.
Is it OK to use Firewire disks formatted under OSX with PT 5.x in OS9?
Also, has anyone used pt6 with (unqualified by digi) disks formatted under OS9?
Izhar
Old 05-29-2003, 08:56 AM
DigiTechSupt's Avatar
ashdot,
We have seen quite a few problems with drives that are not formatted with Disk Utility in OS X. This is a commonly skipped setup item and it can cause performance issues. An OS X formatted drive should work well in OS 9 if you choose to install the Mac OS 9 drivers as alucard mentioned.
Mike
Avid Audio Tech Support
Support FAQ
Pro Tools M-Powered Setup and General Troubleshooting DigiTechSupt Pro Tools M-Powered (Mac) 4 05-11-2010 02:31 PM
Pro Tools MP Setup and General Troubleshooting verbal2796 Pro Tools M-Powered (Mac) 0 06-17-2007 07:52 PM
Pro Tools MP Setup and General Troubleshooting PaulArditti Pro Tools M-Powered (Mac) 0 06-17-2007 12:20 PM
Re:OS X / Pro Tools 6.x setup and general troubleshooting dannepop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-29-2003 11:56 PM
OS X/Pro Tools 6.x setup and general troubleshooting / really? Robocop Pro Tools TDM Systems (Mac) 1 05-29-2003 06:36 AM
