Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 02-14-2007, 02:50 AM
milet22 milet22 is offline
Default ProjectMix - Doesn\'t appear in \"Midi Controllers\"
The ProjectMix audio interface works (i.e. I can record and monitor) but I can't use the surface part in PTMP. When I open up the Hardware->Peripherals->Midi Controllers page, it says "None" under type.
Under machine control and synchronization, it does list the ProjectMix-External and ProjectMix-Control, but not for midi controllers.
I have made sure to set ProjectMix for Pro Tools mode, and it then shows "-----" where the track names should be.
Thanks for your help,
Rob
Old 02-14-2007, 03:19 PM
bradch00 bradch00 is offline
Default Re: ProjectMix - Doesn\'t appear in \"Midi Controllers\"
The "type" field is a pull down list, you should select "HUI as the type and PrjctMxCntr (Receive From) and (Send To).
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Midi Predifined options in Peripherals\Midi Controllers menu RuffinMedia macOS 3 03-04-2015 04:54 PM
MIDI Virtual Ports not showing up in MIDI Controllers (8.0.5) emiliojazz Pro Tools M-Powered (Mac) 0 02-18-2013 12:03 PM
Midi Controllers - Midi Port Assignment eneezy1 Pro Tools M-Powered (Mac) 1 08-15-2012 08:44 PM
Midi Controllers - Midi Port Assignment eneezy1 macOS 4 07-30-2012 02:40 PM
C8 together with other midi controllers PeVaPu ProControl, Control|24, Command|8 1 09-14-2004 04:23 AM
