Old 05-04-2019, 12:24 AM
Led Led is offline
Default Using SPDID as a hardware insert - SPDIF is early
Just thought I'd put this here in case anyone else has the same issue, I couldn't find an answer under search. I set up a hardware insert using spdif on an RME interface, and the signal was coming back in early rather than late as it does with analog hardware inserts. The answer is to use the "User +/-" window at the bottom of the insert channel fader in the mix window. Send a short pip to the outboard with it set to 100% dry signal, create an audio track with the spdif on the interface as the input. Record it and compare the recorded track to the original one you sent to the outboard and measure the difference between the position of the start of the signal on both tracks, then enter that into the "User +/-" by clicking on it and typing the number in. In my case it was 1163 samples.
Old 05-05-2019, 12:24 PM
Default Re: Using SPDID as a hardware insert - SPDIF is early
Good info. Does the value change if you use a different buffer?
Old 05-06-2019, 05:24 AM
Led Led is offline
Hi, haven't tried with a different buffer size, bit busy but I will at some point soon and report it here first.
Old 05-07-2019, 08:14 PM
Led Led is offline
Hi, that's a no - buffer size doesn't change the +/- de;ay amount needed, stays the same for different buffer sizes. I've saved my PCM80 on spdif as a channel preset with the delay.
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
How to insert hardware as channel insert Lqoau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-19-2012 07:29 AM
Hardware Insert teafan Tips & Tricks 6 12-31-2009 01:20 AM
Does hardware insert MUST be same I/O ? nedd Pro Tools TDM Systems (Mac) 8 03-22-2009 07:42 PM
Hardware Insert How-to stormtrooperpez Pro Tools TDM Systems (Mac) 1 07-17-2002 11:02 PM
