Old 02-17-2019, 03:32 AM
rolybarabas rolybarabas is offline
Default Pro Tools as SMPTE generator
Hello, is there any way to generate SMPTE from Pro Tools? Can I record perhaps SMPTE as an audio track?
Thanks!
Old 02-17-2019, 05:51 AM
Top Jimmy's Avatar
Default Re: Pro Tools as SMPTE generator
http://elteesee.pehrhovey.net/
James Cadwallader
Old 02-17-2019, 06:46 AM
Hi Jimmy, the problem is that I need more than 90 minutes...
Old 02-17-2019, 06:47 AM
Top Jimmy's Avatar
Reaper is free to try. It has a SMPTE file generator.
James Cadwallader
Old 02-17-2019, 07:02 AM
Meads Meads is offline
You could export several files from that site back to back, then stitch them together and consolidate.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 02-17-2019, 07:24 AM
Hi Meads, what means "back to back"? If I stitch two sampte audio regions from 1 to 90 mins, I think the sampte signal will "return" to zero after 00:89:59:24, instead 00:90:00:00. (25fps). Is it right?
Thanks!
Old 02-17-2019, 07:42 AM
Thanks!
You can enter the start TC. So e.g.:
1st file: 01:00:00:00
2nd file: 02:30:00:01
3rd file: 04:00:00:02
etc.
Then import them to PT, stitch them and consolidate. That will give you a TC file ranging from 01:00:00:00 to 05:30:00:03 in that case.
The example you gave is not how TC works. There's no 90 minutes.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 02-17-2019, 07:55 AM
3rd file: 04:00:00:01
etc.
Then import them to PT, stitch them and consolidate. That will give you a TC file ranging from 01:00:00:00 to 05:30:00:01 in that case.
Now I understand! I am not forced to start from zero...
Thanks, Meads!
Old 02-17-2019, 07:57 AM
Thanks, Meads!
You can start wherever you like.
Just mind that there's nothing above "59" regarding hours, minutes and seconds. After that it nulls to the next hour or minute.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 02-17-2019, 08:33 AM
I will keep in mind. Thank you, Meads!
Where can I find a signal generator in Pro Tools wordizbon Pro Tools 2018 10 10-05-2018 05:26 PM
Pro Tools signal generator sine wave creates harmonics / overtones? atticmike Pro Tools 12 10 01-20-2017 11:36 AM
SMPTE Generator plug-in byschmidt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-03-2011 10:29 AM
Pro Tools LE as audio function generator miketeachesclass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-13-2010 12:31 PM
SMPTE generator kCmCg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-30-2003 08:37 PM
