Old 10-05-2018, 02:54 PM
taylor4814 taylor4814 is offline
Default How to Replace 003 Monitor Level Control Potentiometer?
How would I go about replacing the main Monitor Level Control knob potentiometer on my 003 console? Increasing amounts of noise/static while using...
Old 10-05-2018, 05:51 PM
Default Re: How to Replace 003 Monitor Level Control Potentiometer?
1-Get the part(if possible) from an Avid-approved service shop(allproelectronics.com is one). Tear it apart and see how good your soldering skills are
2-Skip the repair and leave it wide open(or use the MAIN outputs) and use a monitor/source selector instead. The Presonus Central Station does a solid job and adds a lot of flexibility(maybe in ways you never even thought about). Other options include Mackie Big Knob, Heritage Audio RAM2000, Presonus Monitor Station
Old 10-06-2018, 05:57 AM
Thanks, maybe that does make more sense for the time being...!
Old 10-06-2018, 06:43 PM
If you do go for the Central Station, be aware of a couple of details:
#1-the earlier models use a PSU that connects with a 5-pin XLR. Those power supplies cannot be replaced(newer version uses what looks like a laptop PSU).
#2-when the volume gets turned way down(lower than most anybody would ever listen), the image will move right(heard this on every one I have listened to). Its never been an issue, just an oddity
Old 10-06-2018, 09:07 PM
Sardi Sardi is offline
Virtually all stereo pots do that. My Dangerous D Box does that and it’s not using cheap pots either.
Some pots are better than others, but the only true way is to use dual mono pots or ideally stepped switches like we prefer in the mastering world. Easy recall and you’re ALWAYS at the same position due to physical resistors in the switches.
The best thing to do with monitor controllers is to calibrate your system so that you’re not using the pot at that point. So have it so you’re altering the dial between say 9 and 3 o’clock.
Old 10-10-2018, 06:17 PM
Good advice For me, if I really need to listen softly, I listen from the next room(leaving the volume at a "usual" level). Its amazing how often that will expose a mix balance issue
Old 10-10-2018, 09:45 PM
SKI's Avatar
SKI SKI is offline
Shouldn't look at it as a band aid, it's more of an enhancement than you might think.
URBAN MUSIC-
(Hip Hop and R&B)
Monitor Switch No Level control suggestions ozzlvlosis Third Party Interfaces 4 02-26-2014 02:44 PM
Anyway to get visual feedback for the Monitor/Control Room level on the Artist Contro Focuret Artist Series 0 11-19-2012 11:46 AM
003 Rack "Phones/Monitor" Potentiometer part number? ASAP! GordonFreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-17-2010 11:28 PM
Dedicated monitor level control instead of desk? derF Pro Tools TDM Systems (Mac) 9 03-22-2004 10:43 AM
Can Pro Control replace a conventional desk? jaffaman Pro Tools TDM Systems (Mac) 42 12-26-1999 04:33 AM
