Old 02-16-2020, 04:29 PM
Eric Lambert's Avatar
Default D-Command talkback button is failing. Help!
As the title says, it's functional about 1/10th of the time now. Pressing the button does nothing. A call to Avid for help with a replacement part, or service center, didn't render anything useful.
a) where can we find the part?
b) can it be installed by the user without a degree in EE?
Old 02-17-2020, 09:16 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: D-Command talkback button is failing. Help!
Just an option but you can use the jack connection on the back for talk back. you could make a custom switch, touch to latch and touch to un-latch type etc and wire it to the jack. or even use a pedal. but either way could be a cheaper option.
I can't remember when i looked at the main section including the transport if the talk-back is swappable. but i don't think it is or at least not easily. or maybe you can just swap out the transport part with the talk back. i don't know would have to remove that main section and look.
I mostly use auto-talkback button instead, is that no use the way you work?
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-17-2020, 11:48 AM
We are using the rear connector for client talkback (and already splitting it twice for a total of 3 external switches) and now using that an additional time, temporarily, as the main switch is being picky. I think you're right that it might require some surgery or larger replacement in order to get back to snuff.
And if that's going to be the case, we'll need a source for that part, too. Again, we're just not getting assistance from Avid so anything we can gather from users would be great.
Old 02-18-2020, 11:54 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
I am having the same issue but with my play button. I took apart my blue and ES D-Commands to see if the buttons are replaceable. They kind of are, if you're really good at de-soldering the pins from the board. But, like you originally asked, you'd need a very specific part number for a replacement switch.
Random push-buttons
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 04-20-2022, 07:19 AM
its2loud its2loud is offline
Contact these guys.
https://advancedmusical.com/
They’re in LA but maybe they can ship parts
Old 04-21-2022, 04:09 AM
Led Led is offline
Pretty sure all the transport and talkback are the same switch,
NKK Switches, part UB-15, still manufactured now.
Remote Talkback Button? laki Avid S4/S6 5 08-03-2015 05:34 PM
Talkback button light permanently ON Segdeoye ICON & C|24 5 07-17-2015 10:56 AM
Talkback button Craig F ICON & C|24 1 04-17-2012 05:13 AM
ANGER AND HATRED for the TALKBACK BUTTON SmokinBaldMonkey ICON & C|24 2 01-20-2011 11:26 PM
talkback button in C\24 La Puerta Pro Tools TDM Systems (Mac) 2 12-14-2008 09:51 PM
