TDM and M-Powered on same PC?
I run TDM 6.7 on Windows XP, but I would like to
buy M-Powered to run on the same PC for testing M-Audio hardware, Is this possible? If not, is there a way to work around to make it work? Maybe log in to Windows XP as a new user?
[G5 1.8Mhz][OS 10.3.5][DP 4.12][Cubase SX2][Ableton Live4][Reason 2.5] [AMD64 3200+ 2000Mhz/1MB L2][XP-Pro] [ProtoolsLE 6.1][Cubase SX2][Reason 3] |
Re: TDM and M-Powered on same PC?
you can mix LE and MP .. but not TDM .. when you install the HD
version, it will complain that there is a version already installed. i don't know of a workaround for this. jeff ps: why do you wish to do this? ... |
Could you not pop another hard drive in, load another version of xp onto it and install LE. In theory the version of PT's that's associated with each version of xp should ignore the other. May have to unplug the hardware.
Never done it, just a theory. |
i don't think it will work because of the registry...
you might be able to use profiles .. jeff |
I say DON'T DO IT: I saw a similar thing on a PTHD system of a studio I work with; they tried to install LE on an HD3 with PT7 already on (just to update the Mbox firmware... smart guys, isn't it) and not only they didn't make it with the LE install, but made a complete mess of the HD setup, and this was on a G5, so I guess it could only be worse on a Windows machine...since PTHD had really big issues with stability upon session opnening, and reinstalling PT7 wasn't fixing it, the only soultion they found was to wipe the system drive clean and start from scratch (AAAhhhh ) can you belive this??
Hope this helps L.G. |
LOL, I'm not surprised it didn't work. Two dae's et al on the same system drive is just askin' for trouble. I still think that if you have a seperate hard drive with a second install of xp and you boot from that drive, it shouldn't even recognize that you have an HD system. It would probably try to install drivers when you boot up, but I'd just go into the hardware setup and disable 'em.
I know on a mac you can have 2 operating systems (in my case OS9 and OSX) on 2 seperate drives and run 2 deferent versions of PT's with the same hardware. Like I said, I've never done the 2 hardware things, I'm just theorizing ... or is it Hypothisizing If you decide to be crazy enough to try this, be sure to let us know if it works or just melts down. Good Luck, Ter |
I have my OS drive partitioned and have a separate complete installation of windows XP on each partition. When I boot my PC, I have a menu allowing me to choose which OS to boot to. One is set up with my internet, video editing, graphics, general audio and other programs (with the digi drivers for my 001) and the other is totally dedicated to Protools.
This setup has worked flawlessly for me for the last five years. The only catch I see with using LE and TDM on the same PC no matter how you have your drives and operating systems set up is that the TDM hardware would be seen on either OS and could cause problems with LE. You would probably need to disconnect your M-Powered hardware to use TDM too.
Video tour of my AusDisciples project studio
Studio rig - 002r, Onyx 1640 & 1620, PT8, REAPER, Win7 64, Q9450 quad, Asus P5Q, CMLabs MotorMate and MotorMix, CMLabs Sixty Four Router, Motu Midi Timepiece AV Second rig - Mbox2 Pro, PT8, REAPER, Win7 32, Asus M51sn laptop Live tracking rig - Onyx 1640 & 1620, REAPER, WinXP, Asus M51sn laptop My Website |
M-Powered 8 Essential -> M-Powered 8 Upgrade | Snowblind | Pro Tools SE and Essential (Win) | 2 | 08-09-2011 07:05 AM |
mac osx, m powered fast track, pro tools m powered | singdance6 | Pro Tools M-Powered (Mac) | 2 | 12-22-2010 09:24 AM |
Please Advise are Pro Tools M-Powered Essential the same as LE M-Powered? | jeremiah0812 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-19-2010 10:10 AM |
PT M-Powered with FW400 bus powered audio drive? | bruceup | Pro Tools M-Powered (Mac) | 5 | 07-06-2006 01:32 PM |
bus powered interface + bus powered enclosure ? | technician | Pro Tools M-Powered (Mac) | 0 | 03-20-2006 05:34 AM |
