P750 & Mojo
I'm lookin' to put together an HD system on XP and I'm curious if anyone is running 3 monitors with the Matrox P750 while outputting the video through a Mojo? If so, any specifics I should know about or problems.
Tks Ter |
Re: P750 & Mojo
I'm running the P750 but I don't have the Mojo. I guess if you're going to use the P750 strictly as 3 VGA monitors you souldn't have any probolems as the Mojo works off a completely separate pattern; I'm using the P750 as a dual head + feature preview monitor, it works great, though I've read on the PTLE forum that other solutions are available, like using 2 dual head PCI cards (frm NVidia)with the second configured as 1 monitor, 1 video, and that will work under QT7 too.
Hope this helps L.G. |
Re: P750 & Mojo
Tks L.G.,
I'm running the P750 on my LE system and it works great (aside for one gliche when switching settings sometimes) - 2 mon's and one feature, 2 mon's in clone mode, but I've been usuing it with 3 mon's stretched the majority of the time and I know I'll miss having 3 mon's. The plan is 3 16X9 mon's for the HD rig and the mojo for video. From everything I've read, it should work and I won't have to worry about any gliches from changing settings. Thanks for the info though. If anyone is running this setup I'd appreciate a confirmation that it will in fact work. Tks Ter |
Matrox P750 and Quicktime probs..? | K.B. | Post - Surround - Video | 0 | 03-14-2008 09:15 AM |
video out via matrox p750 with pt 7.3 | cinemasyon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-17-2007 07:22 AM |
Matrox P750 and video playback | paul16 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-15-2006 11:38 AM |
Matrox P750, QT and Pro Tools: a few steps ahead.. | gerax | Post - Surround - Video | 4 | 06-19-2005 04:02 PM |
Video Playback Problems With Matrox P750 | gerax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-20-2004 03:50 AM |
