Old 05-14-2009, 02:16 AM
Gary Nattrass Gary Nattrass is offline
Default Max levels for broadcast in the UK and Europe
A lot of people ask what are the max levels for broadcast delivery in the UK and most of europe so I did a short you tube clip to show the max +8 PPM:http://www.youtube.com/watch?v=CX14GmG17nE
1khz Line up tone would be 0db=-18dbfs=4ppm=-4vu=test on this EBU scale
Max broadcast level is +8db=-10dbfs=6ppm=+4vu=+8 on this EBU scale
Note that the Master 1 dbfs meter to the left of the PPM is not showing a level of around -10dbfs this is because the meter is pre final compression, there is around 3-6db of gain reduction before final output making sure that the levels never go above +8db.
Hope this helps.
Over 30 years in Broadcast Film and TV: www.HDProductionSolutions.com
Old 05-14-2009, 02:29 AM
mr.armadillo mr.armadillo is offline
Default Re: Max levels for broadcast in the UK and Europe
Actually, max. broadcast level for "most of europe" is -9dBfs.
Old 05-14-2009, 03:03 AM
Thanks that will add an extra 1db safety net, people also always need to remember that max level means just that and an average of -18 to -10dbfs is best practice.
Taking the levels to the max allowed anywhere will run you the risk of a rejected programme as not all meters are calibrated the same, in the case of chromatec and on screen meters like PPMulator they are still not as accurate as an old fashioned BBC type needle PPM.
Old 05-14-2009, 03:09 AM
In Germany Studio-ref. is at +6dBu so. Max. broadcast level is:
-9dBFs=+6dBu=0dB on a DIN scale peak-meter.
Ref.-Tone is 9dB below max-level so -18dBFs or -9dB on a DIN scale meter.
Frank.
PTHDn 2020.5 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 05-14-2009, 03:15 AM
More reading here:http://www.ebu.ch/en/technical/trev/trev_293-emmett.pdf
Old 05-14-2009, 06:02 AM
Originally Posted by Gary Nattrass View Post
That means: +7db=-9dbfs=5.75ppm=+3vu=+7 on this EBU scale
I believe you got your stuff backwards. It means:
+ 9dB = -9dbfs = 6.25 PPM (BBC)
Old 05-14-2009, 07:50 AM
I stand corrected the great thing about standards is that there are so many of them, I was originally working to BBC and EBU specifications
Old 05-14-2009, 03:39 PM
infiniteloop infiniteloop is offline
absolutely. bloody online editors turning my mixes down because their "PPM"s in the Harris SDI metering is nothing like BBC PPM ballistics.
Old 05-14-2009, 08:25 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
All those bits going to waste!!!
Old 05-15-2009, 02:30 AM
Thats Numberwang!
HTML code is On
Broadcast levels again! yazoo Post - Surround - Video 32 11-10-2009 01:52 AM
Appropriate Levels for Broadcast TV Rwave Post - Surround - Video 3 03-26-2008 04:00 PM
Broadcast levels vs. Podcast levels... McBoob Post - Surround - Video 0 05-05-2006 08:03 AM
Broadcast Levels? qmix2 Post - Surround - Video 32 10-17-2005 11:13 AM
On broadcast levels and QC... JRogers Post - Surround - Video 8 04-22-2005 10:26 AM
