Old 11-08-2012, 08:20 PM
bergj00 bergj00 is offline
Default Assigning focus fader in dual operator mode - d control
We have a 32 channel d control - 16 faders on each side of the main unit. We have 2 hdx systems tided to the desk. One mixer will use the left bank of 16 and the main unit with one hdx. The other mixer will be using the right 16 with the second hdx. They are linked via satellite.
Is there a way to assign the right focus fader strip to the second mixer? It would be much easier to switch automation modes etc if he had control of this. Is it possible with this set up?
Old 11-09-2012, 11:43 AM
Default Re: Assigning focus fader in dual operator mode - d control
bump
Old 11-10-2012, 01:29 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Yes should be possible. You can on bugger / multiple unit systems even decide which units are and which are not in Multimode. In your config you could decide to have the Main unit only in multi mode and the faders pack in single mode.
Next step then is to assign each fader pack to only the system it will be used for and the Main unit to both.
Are your units in Multi Mode ?
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 11-11-2012, 09:12 AM
Hi Chris! Yes all 3 modes are in multi mode. If they both share the main unit, how can mixer 2 jump in and out of automation settings and global preferences without affecting the other mixer?
Old 11-19-2012, 02:52 PM
moofie moofie is offline
Chris
Gidday Chris,
So just to clarify, with 2 PT rigs attached to a single D-Control Main Unit (with an extra fader pack connected), we can lock the extra 16 ch's of faders to the second PT rig?
Cheers
Tom
Dubber: Mac Studio M1 Ultra, Ventura 13.1, 64 GB RAM, PT Ultimate 2022.12, HDX 1, Sync HD, HD I/O x 2, HD MADI x 1, Black Magic UltraStudio HD Mini, Satellite Link. Source 1 Rig: Mac Studio M1 Ultra, Ventura 13.1, 64 GB RAM, PT Ultimate 2022.12, HDX 3, Sync HD, HD MADI x 1, Satellite Link. Source 2 Rig: 2 x 3.46 6-Core Intel, 10.13.6, 64gb RAM, PT Ultimate 2019.10, HDX 1, Sync HD, HD I/O x 1, HD MADI x 1, Satellite Link. SSL X-8 MADI Router. Dolby CP750 Cinema Processor. 2 x D-Control ES (Dual Operator). Colin Broad PD-1. Colin Broad TMC-1
Old 12-09-2012, 07:54 AM
thierryd thierryd is offline
Originally Posted by moofie View Post
Gidday Chris,
Yes, this is possible (though PT doesn't really like you to change the ethernet setups without crashing . I recently did a film mix final this way: Main unit in multi-mode. The 2 16ch Fader banks in single mode with each bank linked to a different satellite PT system.
You just have to keep track on which modifier keys you're pushing to do things on the right PT system
It would be great if the USB keyboard in the Main Unit would switch between PT systems as well together with the machine multimode switching but alas...
I use screen sharing a lot.
Greetings,
Thierry
http://www.a-sound.com/
Old 12-09-2012, 08:15 AM
Just to add for the OP, the main unit in mulit-mode will always be attached to the selected PT system. So you can't have 2 operators at the same time using the main unit. In bigger setups with 2 or 3 man mixing, there will always be 2 or 3 main units, with each operator having his own main unit and fader banks.
Greetings,
Thierry
Old 12-12-2012, 09:51 AM
Greetings,
Thierry
Right, that's usually how it works. I was just asking about the right "focus" strip that is attached to the main unit. It would be great if that could be assigned to the second mixer. It doesn't seem like it's possible, because you need to assign the full unit to one PT rig (at a time).
Thanks!
Josh
Focus Fader when in VCA mode? audioluche ICON & C|24 5 02-06-2012 09:56 AM
control 24 - fader always in T mode manciosax ICON & C|24 2 02-05-2010 05:46 AM
Focus Mode - M and / Keys Chief Technician Post - Surround - Video 5 07-14-2006 02:05 AM
Bug or Operator Error?: Frozen Fader Bryan Pro Tools TDM Systems (Mac) 0 03-28-2001 11:02 AM
Commands focus mode??? earhere Digidesign Hardware & Software 1 01-04-2001 04:48 AM
