#21
Re: Vienna Ensemble PRO 5
So far I've noticed with VEP 5.
• Hitting spacebar in VEP5 does not start play. This is a known bug. • Menus and sub menus disappear when held for a couple of seconds. • Automation of Waves plugs doesn't work. • I'm noticing some freezing of meters when plug windows are open and you grab a fader to move it. I've worked solidly for 2 days with it and it opened my old session without any problems. Please let me know if you get Waves plugs to automate.
HD Accel 2, Magma PER64-I Mac Pro 2x3.2 Quad Core/OSX 10.6.8/VEPro/PT9.03 http://philbuckle.com/ |
#22
So far, VE Pro 5 has been doing great here. The added ability to sync clocking and transport info to the host via a network was my motivation to upgrade.
Pro Mac Quad 2.26 GHz Intel Xenon Mac OS 10.6.8 17 GB Ram Magma PE64r Pro Tools 10 HD (5 pci-x cards) 192 i/o Apogee Big Ben Slave PC: Vision DAW i7 8GB RAM Windows 7 Pro 64 bit VI's on VE pro 5: Omnisphere G-Player-64bit Kontakt 4 Play 3.0.25 64bit |
#23
HONK! alert.... am i right in thinking this audio input plug sends the channel audio to vienna? So could this finally be the solution to stemming on tools, one of these plugs at the end of each insert chain sending over to vienna and then a bidule like multi track recorder plug or similar being used to record the results? wow, that could be worth admission price alone....
How many of these audio input plugs can you have? |
#24
Correct, I think it is 16 stereo audio inputs / per instance at least. Can be 32, I´m not in my studio now, but it is plenty. You can also open another VEP instance for more...
yes, you are sending audio from your DAW through network ( or local network ) into VEP. Routing back on a VEP output of your choice.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
#25
D
ProTools 9.02 2 x Intel Xeon x5675 3.07GHz Hex Core 48GB RAM Windows 7 (x64)Pro RME Multiface II Intensity ATI HD5400 series graphics card |
#26
Unfortunately the current MIDI bug which makes Pro Tools 10 really unresponsive for many tasks (at least for Windows users), takes much of the fun to be had with VE Pro 5 away again
Once that bug is fixed: !
FR: MIDI Playlist View |
#27
I'm loving the Aux outputs for multi-out VI's.... A huge help!
So far so good with VEPro 5... A fabulous upgrade. Sent from my iPhone using Tapatalk
Mac Pro 2019 3.5GHz 8 Core 48GB RAM OS 13.6.3 Protools Studio 2023.12 Antelope Orion 32, Vienna Ensemble Pro 5, UAD Quad PCIe |
#28
I'm having trouble trying to connect my Server Interface (PT10) to my Standalone (VE5), both running on the same Mac. Any clue? Thanks.
PT Ultimate 2024.3 PT HDX MacPro 7,1 (Intel) 16 Core 96 GB ram macOS Ventura 13.4 Somehow, musicians are now technicians! |
#29
#30
D
Vienna Ensemble Pro | Belegur | Virtual Instruments | 23 | 03-31-2015 01:07 PM |
with PT 11... no more Vienna Ensemble Pro? | Anibal | Pro Tools 11 | 14 | 11-06-2013 11:04 AM |
PT and Vienna Ensemble Pro | wolfhound | Pro Tools TDM Systems (Mac) | 4 | 02-19-2013 09:03 PM |
Vienna Ensemble Pro | d.f. | Pro Tools TDM Systems (Mac) | 154 | 06-11-2012 11:04 AM |
Vienna Ensemble Pro | d.f. | Virtual Instruments | 0 | 03-09-2010 08:22 AM |
