Old 10-02-2013, 10:44 AM
paranerd paranerd is offline
Default ProTools HD 10.3.6 - iZotope RX3 DlgDenoiser 'missing plugin' isn't missing
I keep getting a 'missing plugin' message for a DlgDenoiser insert when it clearly is in the correct plugin folder. I can pull up the DlgDenoiser in the session that has the missing DlgDenoiser. Is there a way to see what plugin file and what folder the 'missing' insert is pointing to?
The Postman Post-Production Studio
Moncton, New Brunswick, Canada
IMDb (very partial)
Old 10-02-2013, 03:04 PM
garnoil garnoil is offline
Default Re: ProTools HD 10.3.6 - iZotope RX3 DlgDenoiser 'missing plugin' isn't missing
When I installed RX 3 it kept the files for RX2. I went to PT 11 and it says: RX2 can not be found but at start up it gives the option to 'move files to unused plugins', and that solved the problem. But, in PT 10.3.7 I now have Rx 2 and Rx 3....I could move the rx2 files to the unused plugins bin.
g
Old 10-03-2013, 06:56 AM
Thanks for the reply, garnoil.
I've done all kinds of plugin folder shuffling to see what the problem is and I really don't understand what's going on. Unless the DlgDenoiser insert that I used throughout an hour doc, iZRX3DialogueDenoiserPTHook.dpm, was somewhere other than /Library/Application Support/Digidesign/Plug-Ins and ProTools was still able to see it, I'm stumped. That's why I would LOVE to know what folder and what file the 'missing insert' in my session is looking when there are only two possible areas and two possible files to look for:
- iZRX3DialogueDenoiserPTHook.dpm in /Library/Application Support/Digidesign/Plug-Ins
- iZRX3DialogueDenoiserAAXHook.aaxplugin in /Library/Application Support/Avid/Audio/Plug-ins
Being in PT10, I can't bring up the RX3 AAX Plug-ins. Like you, I was given the option to move them all to Plug-ins (Unused) when I installed RX3 and I did. Even when they are in Plug-ins, I don't see them in my sessions, so they are to be forgotten.
Plus, if I have iZRX3DialogueDenoiserPTHook.dpm in /Library/Application Support/Digidesign/Plug-Ins, I can bring it up on an insert. But my missing insert is still 'missing'. Obviously, I don't want to re-do all my denoising, so I'm pulling my hair out here trying to figure this out.
IMDb (very partial)
Old 10-03-2013, 07:30 AM
try this: make new blank session with 1 blank track and see if you can insert the denoises and also check for audio suite. If the denoiser is in this new session, then, do a session data import and import the data from the session with the problem. This way, you at least have the session back, then you can try to figure out where Izotope ot PT is putting these new plugins.
I am very new to Pro-Tools 11 but when I installed it it also installed PT 10.3.7 and it looks like the plugin folders for PT 11 are not the same as for PT 10 but certain plugins like Izotope work on both versions of PT on the same computer so they must be installing in both folders.
I had a similar problem with Nugen ISL, when I opened a session it said "nugen not found' so the track would come with Nugen not active but I could insert another Nugen right on the same track. So it did not fin the original Nugen (somehow that became disabled) but the new version was active and insertable. To keep the automation for Nugen, I made new tracks and copied the data by hand (highlight the entire track and copy to the new track below with the new Nugen) and that worked.
Old 10-03-2013, 07:39 AM
I give it a shot. I also thought to just copy my automation from my 'missing insert' bus to a duplicate bus with an automated DlgDenoiser on it, but it wouldn't copy the old DlgDenoiser automation...
IMDb (very partial)
Missing fade files, missing audio in resaved sesssions drygruo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-14-2010 04:56 PM
izotope file missing ramiro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-29-2009 11:37 PM
Error when opening sessions (missing iZotope*_Radius_Win32) beggehorn Pro Tools TDM Systems (Win) 0 03-17-2008 11:37 AM
Protools LE 7.3 - Reason/TRacks/etc - missing in plugin list scalhoun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-06-2007 08:13 AM
Izotope plug-ins missing "Process" button in AS Tray-LA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-16-2006 02:05 PM
