Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 11-19-2009, 08:55 PM
nod25 nod25 is offline
Default Re: EZdrummer-routing tracks in pro tools
Originally Posted by Luke K View Post
I tried that...had all of the tracks from ez drummer routed into imputs (via the plugin bus) but when i record enabled them and tried to record the drum tracks into them i go no sound and no signal?
As far as i can tell im doing it right....any ideas?
Got a number I can call you? I'm in Brisbane. Or email a number to me ?
Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance?
Old 11-20-2009, 08:10 AM
Maybe post a screen shot? It works perfectly me for me on both PC/LE and HD/Mac.
Old 11-20-2009, 02:54 PM
I suggest logging into your Toontrack user account and downloading the Pro Tools Multi Out Template.
Old 11-21-2009, 03:38 PM
Luke K Luke K is offline
Ill try the toontrack template and if that doesnt work ill send a number...thanks guys
Intel Quad Core 2.83 ghz
4 Gig Ram
2x 1Tb 7200rpm seagate Hard Drives
Pro tools 8.0.1
003 Rack
Mackie Mr5 monitors
Windows Vista Home Premium Sp1
Old 11-30-2009, 01:47 AM
up4days up4days is offline
definitely. BTW can you send me that? cant get a TT acct til I get my license issue straightened out.
So far all i can get out as a separate track is the kick
The kick will be on your initial EZ track in PT, I just assign everything else (2-8) to 7 additional tracks in PT as other posters said. Once you do it once and you're set up then save the preset. Its awesomely easy , doing one at a time will take 8 times as long.. The whole purpose of the EZ mixer is so you can simultaneously send out as many or as few tracks as you want.
  #16
Old 11-30-2009, 03:16 PM
What are the forum rules? I could post a box.net link maybe?
Or post your email addy?
  #17
Old 11-30-2009, 08:31 PM
just pm'd you with my email .. thanks!!
  #18
Old 12-02-2009, 04:52 AM
Originally Posted by albee1952 View Post
Just go into the ezdrummer mixer window and select the "TRACK", then create the stereo aux tracks in your PT session and set the inputs for the ezdrummer TRACKS. Once you get that setup, save the ezdrummer config as a preset. I have several, including kits with and without cymbals(if the drummer uses real brass). The "no cymbals" presets load really fast.
How does ur EZ remember the routing to PT? because I saved a preset, then changed beats and came back to the one I saved, and EZ didnt save the routing I had assigned to the protools tracks..
  #19
Old 02-05-2010, 06:37 PM
AirborneFO AirborneFO is offline
Albee..............Once again you are the MAN!
Followed this EXACTLY and the SDK9 is chirpin' like a bird! BUT......(there is always a but )
My question is this....
I have it set as the following:
Stereo Trk1 EZD VST (Bass Drum)
Aux 1 Snare T
Aux 2 Tom3
Aux 3 Tom4
Aux 4 Tom5
Aux 6 Overhead
Aux 7 Room
Aux 8 Como Mix
Bleed control is off. I think this is all good. I can't really "solo" anything per se other than the snare, bass, and toms. It seems to capture everything. So I guess my question is........did I do it right?
iMac i5, Pro Tools 10.2, DIGI003 Command, Akai MPK49, Simmons SDK9
AKA: HoFo
"Yes, recording to the system drive is 99% likely THE main problem." sw rec
  #20
Old 02-06-2010, 06:19 AM
cqd cqd is offline
yeah, has the OP routed the outputs in the mixer in ezd?
ezdrummer how to route to seperate tracks? Jim harris Virtual Instruments 6 04-19-2013 10:31 AM
Do you compress and EQ Ezdrummer tracks? tobbenos The Drum Room 5 08-12-2011 08:00 PM
aux tracks and EZDrummer orvillej 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-06-2010 04:36 PM
Problem with EZDrummer Midi tracks Artfuldodger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-31-2009 01:08 PM
Routing tracks to headphones WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-05-2004 05:42 PM
