Old 08-13-2006, 09:36 AM
vineband vineband is offline
Default Playback is Delayed After Tracking
I am a longtime pt user and i have a problem that i can't solve. On my 002 6.4 set up i track in low latency mode (the only way my centrino duo behaves) and it records well. When i play back it is visually and audibbly about 50ms behind. I am crippled with this problem. Any obvious solutions?
Mike O'Brien
www.myspace.com/luckosoundstudio
Old 08-13-2006, 11:01 AM
AlexLakis AlexLakis is offline
Default Re: Playback is Delayed After Tracking
Well, an obvious temporary solution would be to nudge the tracks right after you record them. Highlight the track and press ALT-H then nudge each track earlier 50ms (or whatever.)
Not quite sure what the problem could be...Is it the same amount of latency every time you record? Is it introduced on all inputs and busses as well? What is your clocking setup looking like?
Old 08-17-2006, 09:38 AM
i had an Waves L3 on the master fader... it wrote the track slow. took me 10 mins on customer support to find the problem.
Mike O'Brien
delayed playback - beachballs lasse456 Pro Tools 11 1 01-02-2014 01:01 PM
Delayed vocals on playback Scorpio253 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-02-2009 03:18 AM
Delayed playback throwing me off tempo! Cone8834 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-05-2006 02:32 AM
Audio Tracks Delayed in Playback Baughb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2003 10:43 PM
Delayed/distorted playback... groucho Digidesign Hardware & Software 1 05-16-2001 02:51 PM
