Old 09-18-2014, 04:03 PM
tg4878 tg4878 is offline
Default Digirewire.dpm locking at startup! [SOLVED]
Hey Gents
Running a Mac with OS 10.8.5. Just upgraded Pro Tools to 10.3.9 and since, at startup Pro Tools hangs up at the digirewire load. Using an 002R at the present. If I remove it from the plugins folder, everything boots fine. Need to run Reason 6 via rewire, and cant figure out a work around yet.
Trashed the preferences to no avail!
Any ideas?
Old 09-18-2014, 07:10 PM
Lightbulb Re: Digirewire.dpm locking at startup!
Have you search Propellerheads' website for how to uninstall ReWire? I think DigiReWire.dpm just calls or loads whatever ReWire was installed by Propellerheads at /Library/Application Support/Propellerhead Software/ReWire.
Old 09-19-2014, 07:48 AM
Default Re: Digirewire.dpm locking at startup!
Thanks for the response and I'll try!
Old 09-20-2014, 02:51 AM
Johnathan knows his stuff but if I recall correctly a DigiRewire.dpm hang at launch refers to a plug-in incompatibility, could be wrong, it's been a little while. However, I'm not going to but you could search the Avid Knowledge Base, alternatively.
Aaron Mulqueen - 001 HD Native
Old 09-22-2014, 08:26 AM
Thank you all for chiming in.
Found an answer at Gearsluts. Any version of Reason from 6.0 on defaults to 64bit mode. All that was required was to click on the Reason app, hit get info, and click on the run in 32 bit mode. Bingo!
Thanks again!
locking on startup -MC control_logic9 john1192 Artist Series 10 06-11-2010 11:53 AM
locking up during startup dumdrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-25-2007 03:39 PM
Digirewire plugin crashes 7LE on app startup Reactor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2005 09:17 AM
Digirewire crashes Protools LE on startup dancheung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-16-2004 12:25 AM
Digirewire crashes on startup dancheung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-04-2004 05:10 PM
