midi studio set up..yamaha dd-65 not listed
hi guys...first time user
my yamaha dd-65 drum pads arent listed in the midi studio setup...i tried using the dd-50 option but it isnt recording the correct sounds are there any plug ins or work arounds i can use? edit...forgot to mention i am using a MIO iConnect MIDI to USB cable thanx Last edited by bklynsburning; 01-28-2018 at 01:04 AM. |
Re: midi studio set up..yamaha dd-65 not listed
I'm not sure which drum plug-in you are using, but there are two ways to correct this.
1.) If the plug-in supports MIDI mapping, you will need to map each drum sound to the same MIDI note number the dd-65 is sending. 2.) The other way would be to assign the MIDI note number the plug-in expects to your dd-65. You can find how to do this in the manual under the Setting The MIDI Note Number section. So for instance, if your plug in expects Tom 1 to be MIDI note number 04, you would have to make sure the pad you are hitting for Tom 1 is sending MIDI note number 04. https://usa.yamaha.com/files/downloa...dd65_en_om.pdf |
thanx for the reply junkgear...just seen this
sorry...im starting from factory defaults and package offered...is there a drum plug in i should buy and add on? |
Yamaha AW16G not listed in MIDI devices | OrangeChicken505 | Pro Tools TDM Systems (Win) | 3 | 05-20-2010 01:28 PM |
Midi Port not listed | ilianarose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-17-2006 09:35 AM |
Midi Port not Listed | ilianarose | MIDI | 0 | 03-17-2006 09:08 AM |
Midi Port not listed | ilianarose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-16-2006 07:14 PM |
Yamaha synth>MIDI Channels>Pro Tools.......Yamaha user's LOOK!! | B-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 12-29-2002 12:58 AM |
