Old 10-19-2017, 01:21 PM
SevenRising SevenRising is offline
Default Incompatible EuCon version Logic Pro X message.
Anyone have any idea what this is all about?
Old 10-19-2017, 05:33 PM
jjnssn jjnssn is offline
I saw it today, however no idea. I haven’t read release notes. You think it would be explained in there.
Old 10-19-2017, 05:44 PM
Default Re: Incompatible EuCon version Logic Pro X message.
Any advice?
Old 10-20-2017, 11:58 AM
Halfmoon Halfmoon is offline
I saw the same when I launched X 10.2.2 after the complete, clean uninstall of 3.6.1 and then installing EUCON 3.7. Clicked "Launch with Eucon" and all seems to work OK regardless (PT Dock). So far so good anyway.
Old 10-20-2017, 01:09 PM
It might be working fine in Logic, but who wants to see this message pop up every single time you launch Logic. Something isn't right and it needs fixing.
Old 10-22-2017, 01:45 AM
[email protected] info@giampaolotestoni.com is offline
New Eucon software 3.7 (138j problem with last Logic Pro X 10.3.2, El Capitan. When I open Logic Pro X , a window pop up say: Incompatible EuCon version. Please update EuCon.
Current EuCon version: 4.0.3 build 138
Minimum EuCon build: 65.916
under these written there are three buttons, first say Launch with EuCon, second say Launch without EuCon and third say Quit.
I’ve tried to reinstall, aven with clean script, I delete Logic preferences but always same window every time. After I click first button, Logic works perfectly with my Artists Control and Mix. Any suggestion?
Old 10-25-2017, 04:35 PM
mattrixx mattrixx is offline
I would suggest that the Eucon support files within LogicProX probably need updating to correctly support Eucon. Logic update required.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 10-29-2017, 05:54 AM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
The EUcon Workstation in System Preferences it the 4.0.3 build 138 build.
I don't know who's need to be updated, if is Logic or EUCon.
If you click use "Launch with Eucon" it will work as it should but that message it will appear every time you launch Logic using EuCon 3.7.
Does anyone have created a case with Avid Support to see what they have to say about this?
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
Old 11-12-2017, 11:24 AM
hanksinclair hanksinclair is offline
Because of this issue I downgraded to 3.6. I miss nothing - after months of hearing nothing from AVID there is a new version - but with bad issues. In addition they are not even able to spend COPY/MOVE/INSERT to the soft keys (after YEARS of software development)???
Old 11-12-2017, 08:42 PM
Eric Lambert's Avatar
My guess is that the issue is with Avid. The previous version of EuCon worked with Logic until EuCon was updated. Now Logic thinks it's outdated though clearly it shouldn't be. Something within EuCon isn't proper.
"incompatible EuCon version" error when launching Logic X MowingDevil Artist Series 6 12-01-2017 08:51 AM
[Logic Pro 9 & Artist Mix] Incompatible EuCon version at initialization w00fa Artist Series 26 04-05-2013 06:17 AM
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but Patrick H macOS 3 11-20-2012 02:46 PM
EuCon 2.6.2 incompatible with Retina MacBook beemer Artist Series 42 11-18-2012 09:06 AM
Incompatible library version: CFnd provides version 7.2.0 heshion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-24-2009 03:42 PM
