Old 12-24-2014, 01:52 AM
Puresonics Puresonics is offline
Default PT 11.3 - Yosemite - Digidesign Midi IO - can't play midi in PT
Hi
Just upgraded to PT 11.3 (HD) with Orion 32 - audio I/O is fine - on Mac Pro running 10.10.1
My Digidesign Midi IO is recognised (amazingly) in Audio/Midi set up and can play 'stand alone' VIs and can also play VIs in Vienna Ensemble Pro 5
BUT I can't play midi in Pro Tools.
There's no connection inside PT.
If I insert a VI with it's own GUI keyboard it plays when I touch it on screen or if I draw in some notes on the arrange page, but not from the Midi IO.
I can set the Instrument channels to the relevent hardware instruments listed in Audio/Midi set up and when I play my Moog the audio runs through the Instrument strip but there's no midi ?
Also I can't play one hardware intrument from any other - ie I cant play my Moog from my master controller even though I can see the lights flashing on the 'in' side of the Midi IO.
I've re-set the Midi I/O - unplugged it's USB cable - trashed it's preferences - reinstalled it's driver - repaired permissions - re-booted many times
Not sure what else to try
Any ideas would be great !
Regards
Lee
Old 12-24-2014, 02:36 AM
Southsidemusic's Avatar
Default Re: PT 11.3 - Yosemite - Digidesign Midi IO - can't play midi in PT
Hi
Just to be sure - You have rec enabled the track and you have gone into the Settings - i/o and pressed default on all tabs aswell as input and output options?
And make sure that midi thru is checked.
I am not in the studio right now so I can't check all the settings we have but I'm sure someone will jump in here who have their setup infront of them
Best of Luck
Merry Christmas
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-24-2014, 08:36 AM
errr......
I don't know what I've done today but it's working again
Old 12-24-2014, 01:21 PM
gives's Avatar
gives gives is online now
Originally Posted by Puresonics View Post
errr......
I have had this happen in several versions.. I restart and it works again fine.. Doesn't happen too much though.
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 12-24-2014, 02:32 PM
Oliver M Oliver M is offline
One simple advice which saved my butt since years:
Keep a copy of the following files (and make sure they are in the right location) prior to installing or updating a PT version:
~/Library/Audio/MIDI Configurations/Default.mcfg
yourHD/Library/Audio/MIDI Drivers/DigidesignMIDIIODriver.plugin
The first file makes sure you use the same MIDI I/O settings, the second one needs to be in place so that it gets updated by the PT installer. If no DigidesignMIDIIODriver.plugin is present the PT installer won't update it NOR install one!!
Old 01-22-2015, 01:46 AM
Mano Mano is offline
Today I had the same problems after upgrading my MacPro to Yosemite and PT 11.3,
The upgrade caused loss of the midi io device driver.
Just go to support and find the latest midi io driver and install it.
The latest possible driver i was able to find was version 9.0.
After installation restart your Mac.
All is fine now !
Old 01-22-2015, 12:51 PM
The latest stand alone installer available is v9, yes but the PT 10 installer updates the MIDI I/O Driver to a higher build. I have no idea if it actually comes with changes but I think the newer the better?!
Old 01-22-2015, 09:59 PM
WorldStudios WorldStudios is offline
I'm on 11.3 HDX Kac 10.10 and my MIDI I/O is working, BUT not well. The timing is way off, worse than if I played it live. You get seasick listening to it. My friend who has a similar setup, has the same issues on Mavericks and Yosemite, but not on Mountain lion or earlier versions. I'm Curious about the later version of the driver. Can someone post it or email it to me? I'm pretty sure 11 does not upgrade the driver and if it does, it is not for the better.
You need to try the playback bug out with a percussive sound. Try some simple chords, 8ths. You will not hear it with a slow pad, but you sure will with a fast sound. I realize the drivers are old and that the hardware is unsupported, but if there is a fix, I would love to know. :)
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
Old 05-15-2015, 09:28 AM
andygray andygray is offline
Default
Did you even get this working ?? I just update to OSX 10.10 my midi i/o is working but timing is really bad.!
Old 05-15-2015, 11:46 PM
Default
Can you confirm your timing is ok with Yosemite ?? My midi I/o is working but time is way off ??
All is fine now !
Midi is played on time but midi notes are early on play back. steveooo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 09-30-2022 12:17 PM
Cant Play Midi digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-22-2011 07:48 AM
MIDI won't play soundguyjosh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-16-2010 10:09 AM
Midi will not play outofblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-13-2006 07:25 AM
How Do I Play Midi rj333 General Discussion 5 12-04-2000 07:03 AM
