Old 09-04-2004, 03:43 PM
cc1 cc1 is offline
Default Shortcuts not working
I often encounter some PT 6.4 shortcuts not working. For instance I'm typing command-8 to show beat detective and nothing happens. Also command-1,2,3,4,5 does not do the functions as shown in the "windows" pull down menu -these commands do different functions. Thanks for help.
cc1
Old 09-05-2004, 01:23 AM
sinnic sinnic is offline
Default Re: Shortcuts not working
Are you pressing the number keys on the Numeric Pad, or the ones over the alpha keys? If the different functions are switching tools, you need to move your hand to the NumPad and then try the shortcut again with those number. If you are hitting the NumPad keys and it ain't working, then I'm clueless besides a system reboot.
Old 09-13-2004, 10:06 AM
Kevin Nettleingham Kevin Nettleingham is offline
This is a bug that I experience all the time. I used to quit Pro Tools and open the session again but that is so time consuming I searched for other workarounds.
Here's the quick one: when the bug appears do a command+tab which will take you to another open program or the finder. Then do it again to get back in Pro Tools, you should have your short cuts back now.
Old 09-23-2004, 10:36 PM
unseen unseen is offline
I also experience this error all the time, usually just in the edit window. Try this: Close the edit window, then reopen by pressing Command= or by going to Window->Show Edit. This usually gets the shortcuts working again.
Brian Morykon
Unseen Sound Studios
Check out Unseen Records artist Jacob Zachary
Mac Made shortcuts Not working in 11 DetroitT Pro Tools 11 3 06-23-2013 05:05 AM
Shortcuts not working mdb Pro Tools Software (Win) 1 03-28-2013 12:50 PM
some shortcuts not working phobic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-15-2011 04:14 AM
Keyboard shortcuts not working estudiomickael Pro Tools M-Powered (Win) 3 09-15-2009 04:05 PM
Shortcuts not Working??? outtareach 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-23-2008 11:34 PM
