Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 05-31-2019, 09:51 AM
MarcOFB MarcOFB is offline
Default Re: Eucontrol download
Originally Posted by BScout View Post
Think you meant this for the other thread (so as not to get OT on this one) but the Madison is strictly 16 in x 16 out AD/DA (and you can chain 4 to use up the full MADI bandwidth.)
I'm unclear what you mean by "digital monitoring" but if you need AES out or SPDIF out, the Madison does not have this. Only MADI and analog.
If you want that, you might look at the SSL Alpha converter boxes.
Yes it was ment for the other post apologies.
Ive sent you a pm btw.
Old 06-01-2019, 07:27 AM
EddieJones's Avatar
S5 only supports up to v3.6.1 (which is internal EUCON v4) If you put anything higher on the machine or even another machine on the same network it won't work. This includes other EUCON software like EuControlo or WSControl. Use the Installer you used to put the newer stuff on and select uninstall All and remove all prefs and then put 3.6.1 back on.
Old 06-01-2019, 07:28 AM
Thank you ever so much Eddie!
Old 06-03-2019, 08:47 AM
putney putney is offline
Yeah, I had lost some functionality. I'm on ws3.6.1 but saw reference to v4.
I'll uninstall, wipe prefs, and install again.
thanks
"What's the best mic under $100."
Old 06-03-2019, 09:01 AM
It worked for me.
Download Artist Mix Firmware from Eucontrol 18.3? sjgam Artist Series 2 10-11-2018 04:56 PM
How to download Eucontrol? Bluto Artist Series 3 09-03-2018 09:18 PM
Can't download EuControl/Workstation 3.4 [SOLVED] andrum Avid S1, S3, Dock and Control App 21 05-14-2016 07:04 PM
Eucontrol V3 download Davekey Artist Series 5 08-20-2013 02:14 AM
Download Manager Stalls during download corym macOS 1 01-31-2012 08:19 AM
