Old 04-04-2018, 10:20 AM
planck planck is offline
Default Artist Control problems
Hello,
I have an artist control and plan to add x2 artist mix to the setup.
However, I’m having problems with the artist control.
It either looses connection and the avid logo appears on the screen and I have to reboot it, or sometimes it completely freezes and I have to unplug the power cable.
I’m running MacOS High Sierra, EuCon 18.3.0.244 and the unit is directly connected to the Mac Pro via Ethernet to the first Ethernet port.
I have gone through all the avid recommendations for using EuCon.
I have had the problems since I got the unit.
Thanks
Alex
Old 04-04-2018, 08:42 PM
EddieJones's Avatar
Default Re: Artist Control problems
Have you tried a different cable ? Is there a specific thing that causes it, does it only do it when you are away ? When you got the unit was it new ?
Old 04-05-2018, 08:39 AM
Different ethernet cable? Yes.
Yes, the unit was new.
The only thing I haven't tried is to change power adapter.
Alex
Old 04-05-2018, 09:03 AM
EddieJones's Avatar
Yes, that's why I was asking if it was new or not. You could try changing the power adapter.
EUCON doesn't like any interruptions, so any power settings like sleep or sleep the Ethernet adapter, AppNap could all have an influence.
Old 04-09-2018, 08:25 PM
Tim Ripley's Avatar
Tim Ripley Tim Ripley is offline
Static IP? Same port being used for internet access or printing, or ??? I'm using a static IP and the port is dedicated the artist mix and control. I use the other ethernet port for everything else. This has always worked flawlessly for me.
Timothy Ripley
Composer, engineer, musician
Mac Pro (Late 2013)
3.5 GHz 6-Core Intel Xeon E5
32 GB 1866 MHz DDR3
AMD FirePro D500 3072 MB
Dual 4Tb Thunderbolt G Drives
Acer B326HUL 32" 2560 X 1440, VIZIO video monitor
Sierra 10.13.2, Pro Tools 18.1.0.241, EuControl 18.3.0.244
Lots of WAVES Plugins, Avid Artist Mix and Control
Digital Performer 9.51, MOTU 1248 (Thunderbolt), MOTU 2408 MkII (x2)
MOTU MTP AV (USB), a bunch of hardware synths, mic preamps, & outboard FX
Experiencing strange problems on the artist control surface; verified with test mode AISM Artist Series 5 08-01-2013 08:52 PM
Avid Artist Control + Logic problems. matthihat Artist Series 3 05-14-2013 04:00 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 09:22 PM
Track select problems with Artist Control Swurveman Artist Series 1 05-18-2012 10:41 AM
Artist Control / Ethernet Connection and Noise Problems lberrios1962 Artist Series 8 05-04-2012 09:20 AM
