Re: S6L - my short list of wishes
My biggest complaint about the desk is status of VCA assignments. When you attention a VCA then go into multiassign mode, the attention status(light) on the desk(button) goes away!
And status of VCA contribution would be priceless. Sent from my SM-G925V using Tapatalk |
Yeah, on the fader bay, the attention button's light turns off when you go into multi-assign mode. I know that if you stay on the VCA screen you can see what's going on, but so many times during a theater show we need to quickly assign and unassign people.
Please update the Snapshot system Like the new Soundcraft Vi series - aux/ group scope per snapshot -Alias funcion like Digico Pre post switches individual per channel per aux - At the moment you can only choose the bus pick-off global. This should be individual per channel per aux. Like the new Soundcraft(s) Vi 2/3/5/7000; Sends can be pre-EQ, pre compressor, pre-fade or post-fade on a per channel/per bus basis (and of course POST MUTE!!) |
Music business is serious business. |
#16
Example CH 1, Kick, Aux 1 Stage monitor (Post EQ Pre Comp) CH 1, Kick, Aux 4 In Ear Vocalist (post EQ Post Comp) CH 34, Lead Vocal, Aux 1 Stage monitor (Pre EQ Pre Comp) CH 34, Lead Vocal, Aux 4 In Ear Vocal (Post EQ Pre Comp) This would make an great Monitor board.And even an small console like an S3L-X Would be more useful for monitors or even monitors and FOH at the same time. Take a look how they have done it in the Newer Soundcraft series, pretty cool |
#17
New feature requests:
- Easy access to plugin-view. When the plugin parameters are spilled on a CKM the corresponding plugin should always be shown on Venue Screen. Or at least an option. - A new Plug-in listing system in the Plug-in rack. If you have many plugins installed on the system, you have to scroll down in the list of available plug-ins, but the way of scrolling is not touch friendly at all, I allways have to grab the mouse (which I want to get rid of along with the Keyboard). It is very easy to select a plug-in instead of scrolling further down. - In 5.3 the Universe view is not working correctly when eg. a VCA is spilled. At least not on my system. I cannot mute or attention when in Spill mode. - When changning showfiles on the S6L there is a audible pop in the PA. It would be great to get rid of. - Option to remove the layout icon in the banking screen and have text only. The text is very small and the logo takes up a lot of screen real-estate. Last edited by Rudio Audio; 10-15-2016 at 10:32 AM. |
#18
But you can make an Event: Trigger: Solo Any Input Action: Change window to plugin. but might not always be desirable. There should be specific input CH. number option for triggers to make it work nicely. |
#19
Re: S6L - my short list of wishes | Dynamic Automation
From my perspective in house of worship, we mix 6 services every weekend. Every one of those services is identical and I already have the ability to have timecode running from the ableton rig that is generating click and stems for the band. If I could record my moves the first service and play them back for the rest, while also being able to update my moves from service to service/song to song it would be amazing. Think Protools automation live to timecode. It would give mixers the ability to make live mixes climb to a whole new level, and in situations where there are multiple shows per day it could keep the mix quality from show to show more consistent. |
#20
1. Create an event triggered by a timecode. 2. Add changing some control as event action. As usual, you can delay a specific action by some time - useful if you need few actions to happen sequentially. 3. Specify X-Fade time for the change to make it smooth. 4. Specify X-Fade curve type to define the easing curve (see http://easings.net/ to understand what it can be) Of course this is not a proper automation, but it allows doing much of it. |
List of short cut keys for PRO TOOLS 11? | Sunshy | Pro Tools 11 | 12 | 09-02-2013 03:34 PM |
if you could have 3 wishes in 3 cat for 11r | Sofus | Eleven Rack | 28 | 07-28-2011 01:21 AM |
Wait a while on Leopard: A prediction and a short list | David Penick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-06-2007 10:50 AM |
My short list of PC shortcomings for post | feakerboo | ProControl, Control|24, Command|8 | 3 | 03-03-2004 04:33 PM |
OT: The short (or not so short list) of... | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-05-2004 05:38 PM |
