Old 05-19-2018, 01:35 PM
robgalpin robgalpin is offline
Default Need help verifying a hardware spec
Hi, Apologies if this is the wrong forum to ask this question. If this is the wrong place to post this please tell me where would be more appropriate.
This is about making sure the computer purchase I am making won't leave me wanting more and needing to buy more to make it work as needed.
My experience is that the Pro Tools documentation describes minimum spec but there are so many details beyond the spec that need to be right in order for all to work well in a specific setup.
I use an MBOX PRO interface - FireWire will require adapter to Thunderbolt, right? It is a home studio. 99% of use is just me recording tracks on at a time - but sometimes need to record a drum set - midi drums with 3 or 4 mics on live cymbals.
I am looking at a refurbished iMac, originally released June 2017 - see detailed spec below. Will this work? Anything to look out for? Thanks - and sorry if this is the wrong place to post this. I was surprised that I could not find discussions on this board about hardware specs - pitfalls and whatnot.
Processor
3.4GHz quad-core 7th-generation Intel Core i5, Turbo Boost up to 3.8GHz
Memory
16GB of 2400MHz DDR4 onboard memory
Storage
1TB Fusion Drive1
Graphics
Radeon Pro 560 with 4GB of VRAM
Video Support and Camera
FaceTime HD camera
Simultaneously supports full native resolution on the built-in display at millions of colors (21.5‑inch) or 1 billion colors (21.5‑inch 4K) and:
One 5120x2880 (5K) external display at 60Hz with support for 1 billion colors, or
Two 3840x2160 (4K UHD) external displays at 60Hz with support for 1 billion colors, or
Two 4096x2304 (4K) external displays at 60Hz with support for millions of colors
Thunderbolt 3 digital video output
Native DisplayPort output over USB‑C
Thunderbolt 2, HDMI, DVI and VGA output supported using adapters (sold separately)
Input/Output
SDXC card slot
Four USB 3 ports (compatible with USB 2)
Two Thunderbolt 3 (USB-C) ports with support for:
DisplayPort
Thunderbolt (up to 40 Gbps)
USB 3.1 Gen 2 (up to 10 Gbps)
Thunderbolt 2, HDMI, DVI, and VGA supported using adapters (sold separately)
10/100/1000BASE-T Gigabit Ethernet (RJ-45 connector)
Kensington lock slot
Old 05-20-2018, 10:11 AM
Default Re: Need help verifying a hardware spec
My 2 cents:
1-i7 instead of i5(you need power)
2-AVOID FUSION DRIVES(get SSD if you can)
Unless you get a big SSD(like 1TB), you'll want a separate recording drive(a good SSD can work for a time, but you don't want to fill your system drive with sessions), so consider adding a fast external drive(this can be tricky as most external drives are not fast). One solution is to buy from a company that specializes in recording drives(like Glyph or AvaStor). Another option is to buy an external case and stuff it with either a fast SSD, or a 7200 rpm spinner(WD Caviar Black are a great choice).
I also recommend a big(like 4TB or bigger) external for backups. I would partition that so that session backups are separate from "system" backups
HP z820 12 core, 64GB RAM, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs, Warm Audio and Midas..............................
Old 05-21-2018, 03:29 AM
musicman691 musicman691 is online now
Originally Posted by albee1952 View Post
My 2 cents:
To add to the above:
Go for the 27 inch as it looks like you're looking at the smaller iMac.
If you go for the 27" do not buy Apple ram but go third party from OWC.
iLoks have been known to have issues with USB3 ports so you might be needing a powered USB hub to go between the computer and iLok.
Lastly and this is a personal preference/thing: get a real mouse with two buttons. I never got along with any Apple mouse. Macs will use any mouse. I like corded rodents.
Old 05-21-2018, 01:33 PM
FWIW, re ilok and USB3, on my rig(PC running Windows 10), I have 3 iLoks and a drive dock plugged into a powered USB3 hub and everything works great
Old 05-21-2018, 04:36 PM
Lucky man I guess.
Old 05-21-2018, 05:53 PM
Lucky man I guess.
Is it that, or is it the newer iLok management software
Verifying DMI pool data hang beatpete Pro Tools 9 0 01-16-2011 10:41 AM
Error #3333 while verifying your authorization. loitschix Pro Tools TDM Systems (Mac) 1 04-14-2008 10:04 AM
Help! Error #-5000 while verifying your authoriza b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-13-2007 06:46 PM
Error 5000 while verifying authorization SNAZ Pro Tools TDM Systems (Mac) 4 02-02-2004 07:50 AM
Error 5000 while verifying authorization Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-01-2003 06:54 AM
