Old 06-04-2019, 09:07 PM
theunibrow theunibrow is offline
Default Problems with input/output setup (using Focusrite Scarlett 2i2)
I have a Focusrite Scarlett 2i2 Second Generation plugged into a MacBook Pro using a Mojave OS.
I'm using Protools First 2018.
I have my electric guitar plugged into my Scarlett 2i2 interface into the first input jack.
I cannot record and do playback without closing my Protools project and reopening it.
I have my Scarlett 2i2 chosen in my Playback Engine, with the record tab chosen. I can record this way, but I cannot hear playback, nor can I hear the metronome.
In order to hear playback, I have to switch to Built-In Output in the Playback Engine. When I do this I can hear the track I recorded, as well as the metronome. The record track tab is still selected. When I try to record with this set up, I get an alert "1 audio track could not be record-enabled because it doesn't have both an input and an output assigned."
As for hardware, I have sound output and alerts/sound effects assigned to Built-in Output (which I am running through headphones) and I have sound input synched to my Scarlett 2i2 USB. I also have Built-in Mic, Pro Tools Aggregate I/O and Aggregate Device options, but no specific functions assigned to these.
So I'm not sure why I cannot record or get playback without shutting the project down and reopening it. And I also cannot hear the metronome to play along with it.
Any ideas?
Thanks!
Old 06-05-2019, 06:05 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Problems with input/output setup (using Focusrite Scarlett 2i2)
Hi have you tried with PT aggregate instead the Focusrite driver ? Please check on mac midi audio settings that Focusrite is added on PT aggregate first . And it is the last Scarlett driver installed ?
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 06-05-2019, 10:19 PM
Hi jeam25,
I appreciate you taking the time to respond.
I tried it with the PT aggregate and I was able to playback (with the metronome) but I couldn't record (I'd just get the same "1 audio track could not be record-enabled because it doesn't have both an input and an output assigned" alert as before).
How do I check to see if I have the last Scarlett driver installed? Where can I find it?
Thanks so much!
i/o setup with Focusrite Scarlett Solo Marvin Losch macOS 4 12-22-2017 05:07 AM
iMac internal mic input and Scarlett 2x2 output? dkrz Pro Tools 12 2 12-02-2016 04:27 AM
Using S/PDIF Output with Focusrite Scarlett 8i6 DonaldM Third Party Interfaces 1 10-03-2014 01:13 PM
Pro Tools 9 and Focusrite Scarlett 8i6 - Problems! willyguitar Pro Tools 9 0 11-28-2012 03:57 AM
input/output setup randyhill87 Windows 1 03-20-2012 09:26 AM
