Old 10-02-2008, 05:16 AM
elicious elicious is offline
Default Tab To Transient Wonderfullness
apologies to b.c.
i thought i'd post this since i realized many who work for us were not aware of this feature and i've even seen recent posts both here and at gs asking for this as an update not aware it's already here as a part of 7.4
and that is the ability to adjust the sensitivity of tab to transient.
(akin to adjusting threshold on strip silence.)
which can be cool for many reasons; if you're a Pensado-style paste each drum hit dude, if you like to use separate at transients, or just want to adjust your t2t flow when editing or automating.
it's a by product of elastic audio...
enable it on any track, view analysis, then go to region> view elastic properties.
make sure you have a complete region selected, then adjust the sensitivity window
(by pulling down on the number).
you'll see the number of markers change as you update the setting.
of course you can edit the markers, also, to suit your needs.
from then on the t2t behavior will follow these settings, even back in waveform view
b.o.l.
e
ihatetyping
Old 10-02-2008, 06:41 AM
Stig Eliassen's Avatar
Default Re: Tab To Transient Wonderfullness
For a guy who hates typing, this is very informative. Thanks.
Old 05-01-2019, 06:18 AM
saspro saspro is offline
This is a cool tip, even a decade later. However, the way I read the OP led me to believe that once elastic's transient threshold is set in ANY region, those t2t settings will be applied universally across the entire session. Instead, it seems it only applies to the clip/region selected. If your track is already divided into multiple selections, you'll have to select them all, and apply.
Nonetheless, this still could be a time-saver in the right session.
Thanks!
Algorithm difference between tab to transient and option + tab to transient? taiga_with_a_pen Tips & Tricks 2 02-13-2010 10:35 AM
What is Tab-To-Transient actually doing? cc1 Pro Tools TDM Systems (Mac) 2 09-04-2005 06:55 PM
tab to transient LuisB Tips & Tricks 4 08-23-2005 02:10 PM
tab to transient LuisB Tips & Tricks 0 08-22-2005 05:00 AM
tab to transient??? BxThree1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-17-2004 01:21 AM
