Superior drummer 64 bit in pro tools 9
Hi guys just updated to superior drummer 2.2.3 which can be 32 bit and 64 bit. I installed the 64 bit update but when i opened superior drummer in pro tools 9 it still said v 2.2.2. i then installed the 32 bit version and tried again and it said version 2.2.3. From what i understand its still only using the 32 bit version, does anyone out there no how to use it in 64 bit mode.
Thanks in advance
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Superior drummer 64 bit in pro tools 9
Well Pro Tools still isn't 64-bit. So you can't use it 64-bit from inside PT. If you have VEPro you can run its 64-bit server and use superior from inside that, otherwise you're stuck in 32-bit mode until Avid catch up.
cheers dude
Raoul Crane
or use toontrack solo...
Superior Drummer not showing up in Pro Tools LE 8.0.4 | Dawija1017 | The Drum Room | 10 | 01-01-2014 10:57 PM |
Pro Tools 11 Not Reading Superior Drummer | BCoop | Virtual Instruments | 5 | 12-22-2013 10:15 PM |
SUPERIOR DRUMMER 2.0 in PRO TOOLS 9 | Leonidas666 | macOS | 2 | 05-25-2011 01:40 PM |
Superior Drummer, TD12 and Pro Tools.... | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-08-2009 06:06 AM |
Superior Drummer + Pro Tools | Mike1983 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-17-2009 04:56 PM |
