Old 09-25-2003, 09:36 PM
Starx Starx is offline
Default No record volumes/Not a valid Audio Drive
I have a G4 Duel processor with 2 160GB Ultra ATA drives. I just bought an Mbox and installed PT 6.0, when I went to put my audio track into record mode I got an error message "No record volumes designated". After hitting ok it opened the workspace window, when I tried to select record for one of my two drives it said it wasn't a valid audio drive. I tried looking through the answer base, tried trashing volume.ddb and pro tools preferances and my OS is .6, not .2, so that was a bust. Does anyone know what is wrong here??
Old 09-25-2003, 11:12 PM
Vertige Vertige is offline
Default Re: No record volumes/Not a valid Audio Drive
Got the same problem here, called PT with no luck so far....
Pascal
The search for knowledge implies also a duty; one must never hide what one has found to be the truth. (Albert Einstein)
Old 09-26-2003, 05:44 AM
where02190 where02190 is offline
How did you format the drives? (FWIW, it's dual, not duel. You have dual drives, and you duel with pistols or swords.)
I'm guessing you did not properly format the drives. Read the manual (online pdf) on formatting drives for Protools.
Old 09-26-2003, 11:32 AM
The formatting is HFS+, I'm told that's correct for working with pro tools.
Windows 7-32bit: all HD are not valid audio volumes shutiri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-25-2010 06:57 AM
Valid Audio Record Volumes Jbdubs Pro Tools TDM Systems (Mac) 14 09-07-2009 06:56 AM
Designate Valid Audio Playback volumes bigcow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 01-01-2008 10:26 AM
Valid audio volumes for Pro Tools M Powered on Mac Book Pro? mezclados Pro Tools M-Powered (Mac) 1 12-17-2007 07:42 AM
not a valid record drive on new g5,- valid on pb?! req06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-20-2006 09:01 AM
