Profire 610 + PT9.0.5 on HP DV7 Win7+64 "Crash" at Restoring Audio Settings **HELP**
Gday,
I Am trying to use my Profire 610 in PT9. If i use any other device, including onboard speakers/headphones via Asio 4 all, PT works perfectly. When i turn off, insert the 610 into 1394 port, power 610 on, then boot up, everything looks fine and 610 is recognised and adjustable via Maudio control panel, perfect. I start up protools, it starts fine and I can see the 610 configured in the Hardware and I/O windows in PT9. Perfect so far. I "create new session" or "open recent session", this is when the problem occurs. As normal, a protools series of progress dialods starts, but when "Restoring Audio Settings" progress dialog appears, it stops ie: The progress bar doesnt even get started. Approx 2 minutes after that the following appears: "Pro tools is unable to reacquire the hardware because it is in use by another program. Please quit that program and then hit ok. If the hardware cant be freed, protools cant continue to run. In this event, hit quit." I have followed everything i can find online ie:forums, including: a) Disable all unnescessary adaptors b) Remove any 610 reference in "laptop Audio Setup", but then tried c) Made 610 Default in "laptop Audio setup" d) Updated ALL drivers e)Restored 1394 to Legacy driver IRQ: I note that the irq is shared IRQ16 with heaps of other resources, inc Graphics, but as it is a "closed" bios (thanks hp!!) i cant do anything aboy it. Can you please have an urgent look and get back to me asap, I use this for educational purposes. Thanks My HP specs are below (via PC Wizard): PC Wizard 2010 Version 1.961 ------------------------------------------------------------------------------------------ Owner: Microsoft Organisation: Microsoft User: Owner Computer Name: STUDIO-LAPTOP Operating System: Windows 7 Ultimate Professional Media Center 6.01.7601 Service Pack 1 Report Date: Saturday 27 August 2011at 12:18 ------------------------------------------------------------------------------------------ <<< System Summary >>> > Mainboard : Compal 30F4 > Chipset : Intel PM45 > Processor : Intel Mobile Core 2 Duo P8400 @ 2266MHz > Physical Memory : 4096MB (2 x 2048 DDR2-SDRAM ) > Video Card : NVIDIA GeForce 9600M GT > Hard Disk : Western Digital WD1600BEVS-00RST0 ATA Device (160GB) > Hard Disk : Western Digital WD3200BEVT-60ZCT0 ATA Device (320GB) > DVD-Rom Drive : Toshiba-Samsung CDDVDW TS-L633L > Monitor Type : LGPhilipsLCD - 17 inches > Network Card : Intel PRO/Wireless 5100 AGN [Shiloh] Network Connection > Network Card : Realtek Semiconductor RTL8168/8111 PCIe Gigabit Ethernet Adapter > Operating System : Windows 7 Ultimate Professional Media Center 6.01.7601 Service Pack 1 (64-bit) > DirectX : Version 11.00 > Windows Performance Index : 4.8 on 7.9 ------------------------------------------------------------------------------------------ ***** End of report ***** |
Re: Profire 610 + PT9.0.5 on HP DV7 Win7+64 "Crash" at Restoring Audio Settings **HEL
The Firewire port on the HP uses a Jmicro and, even worse, shares multiple IRQ with many other items. To resolve this I purchased a Sunix brand 1394 Firewire Cardexpress with the Texas Intsument chipset, it even now states 1394 Texas Inst in the device manager. Additionally, the Cardexpress is on a seprarate IRQ which means it does not have any hardware conflicts at all, and has maximum bandwidth.
The problem still persists any thoughts?? Regards ozbirko |
Hey All, hope this helps
I had the same problem after upgrading to 9.05 from PT 9.03, I solve the problem by re-downloading drivers for Profire 610 and re installing the driver, after that PT saw my Profire 610 -- My theory is that the PT 9.05 update for some reason corrupts the ProFire 610 drivers and the ilock driver (I had to unplug and reconnect my ilock after update) I'm running Win 7 SP 1 let me know if that helps Cheers! |
PT 10.3 Freezes When "Restoring Audio Playlists" | ktuulu | Windows | 9 | 06-14-2016 09:57 PM |
Pro Tools freezes - "restoring audio playlists" | aldersyde | Pro Tools 10 | 6 | 05-13-2014 03:40 PM |
"grey matter" settings gone after a crash? | Frank Kruse | Pro Tools 10 | 11 | 02-08-2012 05:32 AM |
"WIN7" is not an audio playback volume. | govols1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-05-2010 09:27 AM |
Session keeps freezing on opening when it is "Restoring Audio Engine Settings" | bradykrzemien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-18-2009 09:18 AM |
