Energy Saver Dilema
Hopefully ther is an easy fix for this.
I don't have energy saver enabled in the extensions of control panel, however one day the monitor started turning off and in the morning I could get a message saying that the PCI expansion card was not able to be shut down (or something similar to that). Since I don't have energy saver loaded, I can't turn anything off (settings). Tomorrow I ma try to enable it and change the settings, but should enery saver even be working when its dissabled in the extensions and control panels? Any suggestions? |
Re: Energy Saver Dilema
I'm still not exactly sure how that works. Something was screwy with sleep mode on my G4 from day one. It would cause all sorts of crashes and weirdness after waking, even with no PCI cards installed. It would even wake by itself at random and scare the p*ss out of me in the middle of the night. Setting the control panel to 'Never' didn't make a difference. It would still go to sleep after 30 minutes of inactivity. I disabled the control panel and installed a small screen dimmer file called MacDim. Now it goes into a low power mode after about 30 minutes, but not full sleep mode (with the pulsing power button). It cleared up my problems, so I don't question it. What happens when you set your control panel to Never?
-G4's revert to their default energy saver settings when the Energy Saver CP is disabled.
-We always recommend enabling the Energy Saver CP in Extensions Manager and moving the slider to "Never." Brent |
It all makes sense now, I do as you say. Luckily it hasn't caused any problems, but it was kind of bothersome.Thanks!
Airport & Energy Saver at Off | Majorek | Tips & Tricks | 5 | 01-19-2010 07:36 PM |
Energy saver settings on Macbook Pro | wreckthisplace | Pro Tools M-Powered (Mac) | 2 | 01-12-2010 08:57 AM |
Energy saver question | bassbuddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-30-2004 06:56 PM |
10.3.5 Energy Saver on 'Never' but still 'sleeps' | command_shift | Pro Tools TDM Systems (Mac) | 5 | 11-01-2004 08:24 AM |
G5, Energy Saver, Processor performance | parak | Pro Tools TDM Systems (Mac) | 4 | 01-11-2004 11:57 AM |
