Old 04-25-2014, 02:51 PM
JustinCnut JustinCnut is offline
Default BFD2 and Protools.
Alrighty so here it is. I bought BFD2 and I wrote midi to it and all that, it works nice and functions well. Now, I recorded bass and whenever the bass plays and BFD2 at the same time, the snare (and only the snare) pans to the left and everything else stops playing. No kick, no OH's, no room etc..
I have NO Idea what to do.
Old 04-26-2014, 04:21 AM
Default Re: BFD2 and Protools.
When you say you recorded bass do you mean you recorded a bass guitar you played or something from a vi? If a vi are you using PT Instrument tracks? If so and BFD2 and the bass vi are on separate Instrument tracks you shouldn't have issues. If you're using MIDI tracks for the notes and hosting the vi on an aux track watch your MIDI assignments.
Really need more info on exactly what you are doing or trying to do. Completely describe the PT session setup. Also your computer operating system.
Jack
QAPLA!
Old 04-26-2014, 05:59 AM
I have a I7 iMac with 16gbs of Ram and 500gigs of Harddrive (not SSD) and I have a mackie onyx 1640i going directly in protools via firewire.
I have BFD2 loaded as an instrument track and the output is going to Output 1-2 (master) and then I recorded a bass track with my fender jazz going thru my sansamp RBI and then compressor thru channel 2 of my mackie onyx 1640i going in to protools. Its a real track not an instrument track or midi track. Now, when I click play with BFD2 alone, (bass track muted or BFD2 solo'd, doesn't matter it seems) it plays fine. But when I un-mute the bass track or un-solo BFD2, I only get the snare playing. All the other drums and OH and ROOM channels stop playing and I get the dry snare drum only. Weird huh?? Maybe i have to do multiout on BFD2?? I have no idea.
Old 04-26-2014, 07:43 AM
Create a new session with just BFD2 on an Instrument track and hand draw in some MIDI notes and routed to your normal output. Check the BFD2 mixer to make sure your audio outs are all going to the master BFD2 output. Create an empty Audio track also routed to your normal output. Play the session and try muting/unmuting the blank audio track. Unless you have some weird solo thing going on you shouldn't have these kinds of issues. Muting/unmuting/soloing an audio track should have nothing to do with what BFD2 outputs.
I'm thinking you have something else going on you're not telling me about. What version of OSX are you running PT10 on? Remember that Mavericks is not qualified to run PT10 any version and likely will never be qualified.
Jack
QAPLA!
Old 04-26-2014, 07:59 AM
Bill Denton Bill Denton is offline
I'm afraid there is no such thing as "... going in to protools." You have to create things and assign things, and you assign those things to some very specific locations.
From your description, it appears that you created an Instrument track and used some sort of MIDI controller to create a MIDI drum track in BFD.
What next?
Did you create an audio track? Mono or stereo...it should be mono.
Have you set up the I/O in Pro Tools? If not, you need to go into Hardware Setup, then go to each tab on the dialog and click the Default button. You have to do this on every tab.
On your audio track, what I/O did you select?
Are you sure that only the bass track was Record Enabled?
And supply the stuff everyone else asked for...we can't do anything without certain information...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 04-26-2014, 09:59 AM
Damn, I am running Maverick.
BFD2 Win 7 64bit ProTools 8.0.5 crash FIXED! ozchapman The Drum Room 2 12-18-2012 12:29 AM
Do I need to buy BFD2 or BFD2 upgrade if I have BFD ECO? joedexter23 The Drum Room 26 07-23-2012 11:38 AM
BFD2 or BFD2 upgrade from BFD ECO?? joedexter23 Virtual Instruments 2 03-11-2012 12:42 PM
Bfd2 tommykoot Pro Tools M-Powered (Win) 1 11-03-2010 05:58 PM
BFD2 ok in Logic... with not auth in Protools... anthonymunoz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-23-2010 07:23 PM
