Old 04-09-2010, 03:34 PM
ccuwan ccuwan is offline
Default Unwanted crackling noise only upon playback...HELP!!!!
Bump for this issue as I have the same. Has anyone figured out what this wordclock reply is all about. I've got an internal and external clock option on my M-Audio Ultra but I don't think that is what is meant.
Surely there is a simple answer here!!!!
Ray
Old 04-09-2010, 03:54 PM
Default Re: Unwanted crackling noise only upon playback
as everyone has disappeared from this thread I assume the clocksource solution worked for everyone......someone please let me know where I find clocksource in my system....thanks
Old 04-15-2010, 09:51 PM
daxmusic daxmusic is offline
ccuwan, You can change Clock Source in Setup > Hardware. However, I've been having the same crackling problem, and changing clock source didn't seem to help me.
Old 04-15-2010, 09:55 PM
You might try going to Setup > Playback Engine, and adjusting your buffer size, or better yet, reducing your RTAS to 1 processor. I just changed the RTAS setting here, and it immediately eliminated the crackle.
Old 04-16-2010, 05:56 AM
For anyone following this thread or finding it, it appears that the crackling and popping noises are caused by a variety of things generally revolving around the relationship between the M-Audio device and your computer and the speed with which they can talk to each other. As you have read above different people found different solutions. For me it was a simple as changing the USB port that I had plugged into. Simply moved my connector and the crackling stopped. I assume the administrators of this site they are tired of this question as none stepped in to help so here is what I found.
A fairly comprehensive list of possibilities is here:
http://www.m-audio.com/index.php?do=...978a213b6d86ac
Crackling noise in playback mysg4ever Pro Tools SE and Essential (Win) 2 07-08-2014 08:38 PM
Crackling Noise on Playback... of anything itspangler macOS 6 09-04-2012 06:43 PM
Mbox Mini 3 Crackling noise during Playback? khushalbhadra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-09-2011 02:29 AM
8.0.4 crackling noise during playback 003 Factory adtnj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 07-21-2010 12:09 PM
crackling noise????????mbox???????playback???????? klownprince7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-16-2004 02:18 AM
