Re: Automation Question .
I HIGHLY doubt something so incredibly specific to the way a VERY small number of users would want to work (still trying to figure out why) would be implemented.
It'd be like… destructive record mode Drew. Like CDT'ing on the fly. I see your point, but if you don't ask, you definitely won't get.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
That doesn't do it.
The aim is to coalesce on the fly.
This will produce a black automation line and a successive undo for each track without stopping playback when trimming statically :
preview mode trim automation mode select vocal track 1 (really clicking the track name), trim as desired , trim-to-current (Win : Ctrl Shift /) select vocal track 2 , trim as desired , trim-to-current select vocal track 3 , trim as desired , trim-to-current select vocal track 4 , trim as desired , trim-to-current do not hit write-to-all (that would double the trim amount) or any write command just deselect preview It will produce on the fly 4x "Trim to Current", so if vocal track 3 trim was bad and is undone (4 is also lost then), the trim automation of track 1 and 2 is still there. I was looking in the Shortcuts Guide, found this command, never used it before, experimented and remembered this thread. And actually , Gary Gegan's genius very special use of preview and write-to-all-enabled, inspired that. It is a little bit tricky, being in preview but nevertheless having to explicitly select a track .
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 Last edited by joachim; 08-28-2015 at 08:05 AM. |
joachim, it's been a while since this thread was started, but, what you're suggesting sounds like what we were after.
I don't mean to be cheeky, but any chance you could do a wee video of what you're describing ?
#16
That's a challenge, need to get a screen recorder ... .
But it is absolutely simple : make a selection, preview , trim mode , click the track name, move its fader, trim-to-current , click the next track name, move its fader, trim-to-current, .... , done : deselect preview.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
#17
The shortcut trim-to-current is not visible in the video, that one is executed upon the fader move and results in the jump of the volume line.
#18
#19
Thank you, Stig.
(Maybe for others, looking for a simple free screen recorder option : http://www.apowersoft.com/free-online-screen-recorder )
#20
That's useful, but not what I was trying to achieve. . The transport needs to keep rolling for what I was talking about. . And the coalesce needs to be up to where the playback head is . I don't think it's doable in PT.
Mix Automation Question | samskimusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-09-2010 03:37 PM |
General Venue Automation Question - (Maybe dumb question) | TwoPort | VENUE Live Sound Systems | 5 | 12-21-2007 02:41 PM |
A question on automation | Peter Groom | Post - Surround - Video | 5 | 03-03-2007 06:20 PM |
Automation question | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-25-2003 08:09 PM |
automation question | c_hebb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-24-2002 09:47 AM |
