Old 11-04-2019, 02:54 PM
Meads's Avatar
Meads Meads is offline
Default Bug in new video engine 2019.10
I've been putting the new engine through its paces the past couple days and noticed some weird behavior I hadn't seen with the old engine.
Sometimes when I hit stop and play the video plays back in a random loop while the playhead continues through the session normally.
I haven't yet been able to pinpoint a certain trigger for that, but it happens with newly build sessions in 2019.10 as well as with older sessions.
My video files are always ProRes 422 (Proxy), nothing in my setup changed except for the upgraded PT install. Same drives playback the same files in the same sessions.
Never had this issue before.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 11-04-2019, 04:03 PM
reichman's Avatar
reichman reichman is offline
Default Re: Bug in new video engine 2019.10
I also use ProRes proxy (with an AJA T-Tap) and saw this last night, but it was while I was toggling the Weiss plug-in pref for OpenGL graphics. As soon as I said yes to OpenGL and rebooted, all was good. Or maybe this was coincidence.
Video has been fine for me today.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 11-04-2019, 04:09 PM
Meads's Avatar
Interesting. I'm using the Weiss-Deesser in most of my sessions.
Just checked the OpenGL setting and it has been ticked already, so I guess that's not it, as it just happened again.
It's not that big a deal since toggling the video offline/online always solves it for me. But should still be worth a fix.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 11-04-2019, 04:17 PM
Reckless Erik Reckless Erik is offline
I noticed an odd loop today with 2019.10. Playing the last minute of a 45 min show and expected to see the credit roll and got a loop of about 5 secs from video that had already been played. Pro Res proxy file type. 25 fps.
nickcath@internet.is
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.14.6, PT 2019.10 HDn, Avid Artist Control, Avid Artist Mix...,
MacPro 3.5GHz 6 core 64GB RAM OSX 10.14.6, PT 2019.10 HDn, Avid Artist Control, Avid Artist Mix, PT Dock...
Old 11-05-2019, 07:53 AM
Haven't seen this here but all our picture is DNxHD36. And no Weiss plugins installed.
PTHDn 2019.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 11-05-2019, 09:25 AM
Meads's Avatar
I just had it that instead of looping the video freeze framed.
Still haven't figured out, when it does it, but it happens several times a day.
I have a feeling it occurs when hitting play while PT is still busy with another task. I'm very quick when it comes to editing. For instance cutting the end of a clip, creating a fade out and hitting play basically is one action. A quick burst of key commands. Seems those playback issues always happen in one of those instances. But then again I could be totally wrong, it's just a hunch.
Will report back when I figure anything out.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 11-13-2019, 02:11 PM
Ale Ale is offline
Hi
Had the same problems the last days.
Today I had no errors working in a new session from my template.
Means the same plugins are in the session.
The only differnce is that I have this time much less audiosuite plugs open. They are getting more and more as I work.
Did not find the reason till now but I think audiosuite has some impact to the video engine. Doing audiosuite does trigger video problems (black/no video)
Switching video offline/online makes video running again.
Video is always dnxhd36
3x PT HD Ultimate 2019.10 6/12-Core Westmere/ 48 GB / OS 10.12.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2019.6 / MacMini Server late2011 / 16 GB / OS 10.13.6 / 002
www.tonstudio-gress.de
www.facebook.com/TonstudioGress
Old 11-16-2019, 11:22 AM
JanuS JanuS is offline
I had black video window, or 1 frame still video in 2019.10 on my Mac mini which I use as a video satellite machine with Vanilla Protools. Tried most common stuff (delete prefs etc), but no result.
Downgraded back to 2019.6, and everything fine again..
It beats me what's wrong with the AVE in my case...
Old 11-16-2019, 01:49 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Same here DNXHD36 mxf video.
Only when I upgraded to 2019.10
IMDB
Old 11-16-2019, 03:04 PM
henningaround henningaround is offline
Does QuickTime DnxHD36? Mixing a smaller TV 90 Minute feature here and it's ok.
HTML code is On
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 9 12-08-2019 11:37 PM
Problem enabling video engine 2019.6 Lydbildet Windows 11 08-31-2019 02:22 AM
PT 2019 same video problems garnoil Pro Tools 2019 12 05-12-2019 04:50 PM
Video Engine Fail "Waiting for the video engine to launch" oscar_wonderboy macOS 5 08-14-2018 02:22 AM
Video Engine not working.. crashing when i load in a video to PT11 sarahsherlock Pro Tools 11 5 08-16-2014 01:35 AM
