input 1 gain problem/digi 003 console
hello
When i connected a stereo pair of mics to inputs 1-2 i noticed that the gain on input 1 was very low vs. input 2 even though gain knobs were even. there is a signal, it's just so long i have to crank the knob all the way to get any level. i looked up the problem and read that the cables inside could be zip tied to tight and could cause a connector to become unseated. i'm out of warranty, so i opened up my 003 and found that all was seated properly. What else could be causeing the problem? and has anyone else experienced the same, and if so what did you have to do to correct the issue? thanks |
Re: input 1 gain problem/digi 003 console
Have you swapped sources to verify its the input and not the source?
yes. i've tried multiple mics. The DI works fine for imput 1, it seems to be just the mic line in.
digi 002 input gain | dashlogan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-24-2015 11:02 AM |
Used Digi 002 console input #1 doesn't work | rollsrock25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-02-2011 02:46 PM |
digi 002 1-4 input gain | dashlogan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-06-2009 12:53 PM |
Digi 001 input gain problems | cities | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-28-2004 09:16 PM |
Input gain problem with PTLE 6.1 | jnash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 07-23-2003 12:27 AM |
