PT10 and Eleven rack problems
I'm a complete novice but have just bought Eleven rack with PT10 included. It is straight forward to set up and I can control the rig settings from PT on my Macbook but I'm not getting any sound/signal coming through. The I/O is set to Eleven rack L/R (input) and Main Out L/R, record enable and...nothing!
It should be plug in and play and it's probably just some little detail I've overlooked but someone please help me out here! |
Re: PT10 and Eleven rack problems
try defaulting the I/O
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
i'm new here also so welcome as far as i know the i/o input should be "eleven rig" not "Eleven rack L/R". go to audio engine setup on pro tools setup menu to check if it's set to eleven rack, and then set the input i/o on the channel to "eleven rig", enable record the channel and you should be fine. |
A friend helped me sort this out. Had to go to Playback engine, change from Pro Tools aggregate I/O to Eleven Rack and then default the I/O
try alt+k after you enable record the channel
I watched Benoni's video on defaulting the I/O. So my older sessions with messed up I/O settings will just have those extra italicized paths? Is there a way to clean up your old sessions that I'm still working on?
Eleven rack GUI in PT10.3.6 | YYR123 | Eleven Rack | 7 | 08-06-2013 07:19 PM |
Eleven Rack and PT10 | Barry Johns | Eleven Rack | 2 | 04-18-2013 11:42 AM |
Pt10 and eleven rack no playback | benhoulihan | Pro Tools 10 | 4 | 02-23-2013 12:23 PM |
PT10, Eleven Rack and Keystudio | redd1971 | Pro Tools 10 | 0 | 07-18-2012 07:04 AM |
IF I buy Eleven Rack w/PT10 can I upgrade PT . . . | Kevinlane1 | Eleven Rack | 3 | 07-15-2012 04:11 PM |
