Old 06-16-2019, 08:54 PM
awritersparadise awritersparadise is offline
Default anyone use Eleven rack live with patch changes? 60ms silence gap when changing patch
Was thinking of using this out on the road for live.. I would be using different patches and such depending on the section of the song.. but I've noticed when switching patches (manually scrolling right now from one to the next) there's a 60ms silence gap in between switching over to the new patch.. which would be a no go live.. anyone use this successfully live without the noticeable "changing patches" 60 ms pause?
Custom Thermaltake PC / Windows 10 / 16 gigs of ram / Intel I-9 CPU (12 cores) / UAD Apollo Quad Firewire Interface / M.2 System Drive / 5TB Solid State Session Drive / Pro Tools 2019 Subscription
Old 06-16-2019, 09:03 PM
Default Re: anyone use Eleven rack live with patch changes? 60ms silence gap when changing pa
Patch change latency has been discussed here a lot many years ago. You can search and find those past discussions. It is what it is. You can switch effects within a patch, or use two Eleven Racks and a switcher, or get an Axe FX, ...
Old 06-16-2019, 09:05 PM
thanks for the response. much appreciated. research continues! :)
Old 06-16-2019, 09:09 PM
This latency and the inability to have cab emulation off for an on-stage guitar cab and simultaneously on for FOH output are two of the live restrictions with the Eleven Rack that bugged folks. If Chris Townsend had stayed at Avid I'd have hoped there would be some chance those would have been fixed. ... and some more effects added. But alas...
Old 06-17-2019, 10:08 AM
YYR123's Avatar
YYR123 YYR123 is offline
Somewhat reminiscent of what Structure was...
....a really nice product that wasn’t fully developed to be a Top Tier product
Daniel
Old 06-17-2019, 06:15 PM
DonaldR DonaldR is offline
I have not measured but I can feel latency changing patch with the scroll knob but I (almost) don't feel any when using a midi pedal. I use it live and my friend used mine also (when I play bass in the band) and never mentioned anything about latency. But he always reported how crazy this thing is sounding :)
Eleven Rack Patch Change Time - G-System CReedZAT Eleven Rack 10 09-15-2014 11:48 PM
Disabling MIDI patch changes, when recording MIDI through the Eleven Rack? amnesian48 Eleven Rack 2 04-07-2014 01:58 PM
MIDI patch changing from DAW sanjaydas7 Eleven Rack 10 02-16-2014 08:38 AM
Midi Patch Changing CHRIS AIKEN MIDI 0 04-18-2001 10:50 AM
Changing Patch Names?? Mista Digga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-29-2000 06:10 PM
