Old 04-28-2019, 09:35 PM
jjpl2001 jjpl2001 is offline
Default Midi Drum Editor Like Cubase
Hello. I'm trying to find a drum editor like the one I can Find in Cubase.
I know that there is a LOOOOONG workaround for this called "Drum editing matrix"
https://www.youtube.com/watch?v=x3bnbzpKUvI
But still it is missing the flexibility that you can find in Cubase and in Reaper 7 to edit Drum midi tracks.
In protools is a nightmare and is still holding mi back to switch from cubase.
Regards.
Old 04-29-2019, 06:25 PM
anothercolour anothercolour is offline
Default Re: Midi Drum Editor Like Cubase
The editor in Superior Drummer 3 is pretty close, and it can be used as a stand-alone application or as a plugin in Pro Tools.
Old 04-29-2019, 06:41 PM
Yes I know. The problem is that I use Cubase drum editor to switch between Drum plugins according to the occasion, I use Steven Slates, SD3 and Addictive drums for different things. I think it's sad not to have a drum editor like in Reaper7 and Cubase. Its so flexible. You can switch between drum plugins or edit your drum parts on the fly.
Pro tools Midi editor is a pain and a Creativity killer while composing drums and mixing.
Old 07-03-2019, 02:52 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Is why I keep a copy of Cubase some things midi it just does better.... but I think that comes down to the approached these two software packages come from... Cubase has always been big on midi where PT came from the recording of analog systems.... if they could only join together with those two directions. In PT I use Xpanda and edit through the midi edit window for drums these days and it’s pretty good.
Regards.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 12-22-2019, 12:03 AM
TNM TNM is offline
Personally I think an in built step sequencer and arp would be very worthwhile additions to PT and a great expansion of the midi.
Also, a dedicated drum editor is the most important of the lot.. Look how easily and integrated presonus added it in S1 V4.. something like that where you just click in the piano roll to flick between drum and note mode.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
MIDI drum editor midnightrambler Pro Tools 12 19 08-31-2016 02:03 PM
Articulation with drum tracks in midi editor willl3 Pro Tools 10 1 02-23-2014 11:23 AM
Using Pro Tools Midi Editor for BFD2 drum mapping Qrackaduck Virtual Instruments 4 10-15-2009 08:53 AM
Any simple Midi Drum editor for PT7 available? mrsusan Tips & Tricks 1 11-25-2006 08:03 AM
Cubase as midi editor and PT LE as audio CFS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-01-2001 12:33 AM
