Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 09-29-2019, 06:45 PM
Cheesehead Cheesehead is online now
Default Plugin Window follow DAW Track Selection
Even with all these new options in the general tab of Eucon 19.9, is it still not possible to get an open plugin window, or other window to follow your track selection from a mouse click on the timeline?
I've tried all the possible permutations of the new parameters and I can't get PT to do this.
I thought this was one of the new features we were going to get, but it seems to do everything else except that one thing we've been asking for, for as long as I can remember.
Perhaps I'm doing something wrong?
If someone has this working could they point me in the right direction please.
Thanks.
Mac Pro 6,1 12 core, OSX 10.14.6, HD-Native TB, Trinnov MC, 888 IO, 192 IO, Sync HD, AJA IO XT, MC Mix, PT Control, Eucon 19.9, PT 2019.10
Old 09-29-2019, 11:19 PM
BScout BScout is offline
Default Re: Plugin Window follow DAW Track Selection
Isn’t Eucon/Eucontrol about control surfaces? And your request is about mouse-clicks/DAW selection?
Select from the Control app. Or a Eucon surface. Turn on in Eucontrol "Attention Most Recently Clicked DAW Area: Track Name". If you have insert A open, then clicking on another track (in Pro Tools, not just Eucon because now one follows the other) will open the same insert slot. But you have to be on the Inserts slot under Channel tab. If you are using the auto-select by type mapping, if you go from an EQ to Reverb in the same slot then it won't open because it won't match what the control surface is controlling (by type.) However Inserts encapsulates all of them.
And is that the royal “we”? I don’t want every bloody plugin window opening/closing as I’m editing audio or writing automation. That’d be a nightmare to keep clearing those out of the way. I only want the plugin/pan/send window to open that I’m controlling currently from a Eucon surface. Like it works now.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 09-30-2019, 06:35 PM
Ha, 'the royal we' I like it!
Thanks for the instructions, but it still doesn't work on my rig.
Either the open plugin window just stays on the first one that was opened or
if I have 'Close windows on workstation when editing' selected, it closes.
PT Control follows the attentioned track but the plugin window doesn't.
If its working for you I must still have something set wrong.
Old 09-30-2019, 07:01 PM
I'll try to post a screenshot of settings and a video later tonight (PST time.) Have to mirror the Control app actions up to the screen next to Pro Tools so it all gets captured in real time.
Old 10-01-2019, 08:09 AM
Thanks, much appreciated.
Old 10-07-2019, 09:05 AM
Hi there,
Just following up on this.
I've kept trying different options of preferences but still can't get it to work.
If somebody has a plugin reliably following track selection could they give me the magic combination please.
Thanks
Old 10-08-2019, 11:33 AM
Ed Douglas's Avatar
Ed Douglas Ed Douglas is offline
Originally Posted by Cheesehead View Post
Hi there,
Thanks
I feel your pain. I had ALL SORTS of grief with this feature which is essential to how I premix.The trick for me was to Uninstall all applications AND Remove User Preferences with the installer, reboot and install again. Your appsets will remain intact, thankfully.
https://www.flickr.com/photos/ed_dou...posted-public/
Neotech Concepts
http://www.imdb.com/name/nm0235036/
! sonic gymnastics for the illusionary arts !
2019 i9 MacBook Pro (15,3), macOSX 10.14.6, PT Ultimate 2019.10.494, Atmos Production Suite 3.2, MDA Creator1.5, Rx7 Advanced, Ozone 8 Advanced, Kontakt 6.1.1, Soundminer v4.5Pro, Spanner 3.0.5, SoundHack 0.896
EuControl 19.12.0.14, Avid Control 19.12.05, iPad Pro 12.9" gen 1, iPad Pro 12.9" gen 3, Apollo 8 Duo tb2, UAD-2 Satellite Quad tb2, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 4 28TB
Last edited by Ed Douglas; 10-08-2019 at 11:34 AM. Reason: trying to get link to work properly
Old 10-08-2019, 08:22 PM
EddieJones's Avatar
Hi there,
Thanks
What do you have Open Windows on Workstation When Knobs assigned from DAW Click set to ?
Faderport/HUI track selection/track follow from within Pro Tools DAWgEAR Pro Tools 2018 8 03-14-2019 02:19 AM
Setting to make plugin selection in DAW follow channel selection? polyh3dron Pro Tools | S6 12 01-15-2019 12:46 PM
Pan and plugin windows follow selection GuidoHelbling Post - Surround - Video 13 09-25-2014 02:38 PM
C8 Track selection Follow daslicht ProControl, Control|24, Command|8 4 01-11-2011 07:11 AM
mix window does not follow c24 send selection Serge Perron ICON & C|24 0 10-19-2010 07:37 PM
