Old 05-28-2009, 08:13 AM
jjsoundoc jjsoundoc is offline
Default Plug-in for speed change?
Can anyone recommend a plug that would allow you to change speed of a sound while following movement?
An example would be a bike rolling downhill, going faster as reaches bottom.
Ideally, the plug could be controlled dynamically so that you could track movement.
Thanks,
JJ
Old 05-28-2009, 09:24 AM
reichman's Avatar
reichman reichman is offline
Default Re: Plug-in for speed change?
The waveform view in Serato's Pitch 'n' Time Pro in varispeed mode will let you shape a continuous changing varispeed. Sound quality is excellent.
The old school thing to do would be to drop it in a sampler and automate the pitch bend wheel.
Keep in mind that a real-time plug-in can't do what you're looking for. It's going to be Audiosuite, or a standalone app, or a tape deck!
Best,
Nathaniel Reichman
Old 05-28-2009, 09:31 AM
danijel danijel is offline
In Sony Vegas, you can draw clip-based speed automation. It's real-time too!
EDIT: well, it's not a plugin, sorry....
Danijel Milosevic
Old 05-28-2009, 09:42 AM
axiom axiom is offline
Can't you use Elastic Audio and varispeed to do something like this?
Old 05-28-2009, 10:51 PM
Thanks,
JJ
Structure free and pitch-wheel on a keyboard? Automate while watching picture.
frank.
Old 05-29-2009, 08:38 AM
Noiz2 Noiz2 is offline
No, or not really. EA moves in increments and as far as I know there is no way to get it to change smoothly, unless this changed in 8??
www.scottkouesound.com
SK
Old 05-30-2009, 10:14 AM
mikevarela mikevarela is offline
Just a thought, what you might be going for is a doppler effect, though maybe not passing the screen, but waves makes a doppler plugin, try that
NuanceTone.com
Old 05-30-2009, 10:53 AM
Ale Ale is offline
I also want to know.
Here on duc was a post pointing to a brand new automateable pitch plugin. It had also the possibility to change formants.
I am searching for this but do not find it on the web.
Ale
edit
It was not waves, serato ....... it was something really new
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 06-01-2009, 04:16 AM
Felix Rost Felix Rost is offline
http://products.zplane.de/index.php?page=elastiquepitch
http://felixrost.de
Old 06-01-2009, 08:59 AM
Old Man Old Man is offline
You can automate using elastic time if you put your track in Varispeed mode and then automate tempo changes. You draw your tempo changes in with the pencil tool. Unfortunately it affects all tracks at once -- any track that's in ticks, not samples. It's a little jumpy but will work.
The best plug-in for tempo and pitch changes is Sound Toys Speed. Use it in graphical mode to draw in tempo/pitch changes. I used to have this back on my Pro Tools 5 system but didn't buy it since there was so much hype over the new elastic time. Elastic time just doesn't quite deliver as well though. I have heard it has been improved in Pro Tools 8 but I haven't made the upgrade yet.
If you decide to buy Speed, it's probably worth it to buy the whole Native Effects bundle as it's only $100 more and gives you a whole bunch of cool stuff.
Tim
HTML code is On
how can I "speed up" without pitch change? BubbaHoTep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-07-2006 12:11 PM
PAL to NTSC speed change? David Sandwisch Post - Surround - Video 17 09-19-2005 10:08 AM
Change speed and pitch? likegluelikecrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-13-2004 09:37 AM
Change speed secutanudu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-18-2002 04:59 AM
Plug to change track speed? Dr. J Tips & Tricks 4 08-13-2001 12:50 AM
