Old 02-03-2001, 06:55 PM
elik elik is offline
Default Re: Hello Logic users.......Please explain about Logic Midi
The number of devices you can run; or more specifically the number of midi tracks you can run, is a function of the midi interface you are using. So yes, you can run several midi devices simultaneously in Logic with the right midi interface.
Yes, you can split up the midi onto as many tracks as you like. Kik on one track, hi hat on another, etc.
Yes you can record audio into Logic through the 001 and take advantage of all it's features. Importing the tracks back into PT LE, although doable, isn't quite as elegant. OTOH, depending on your working style, there need not be any compelling reason to use PT LE software at all. Logic performs fine as a front end for the 001. While you can't use RTAS plugins in Logic, you _can_ use VST plugins, as well as Logic's own internal plugins that ship with the program.
Lastly, no; MicroLogic AV does not have all of the midi features that Gold and Platinum have. You can see a featur by feature comparison chart for each version of Logic on Emagic's web site at www.emagic.de
Eli Krantzberg
Nightshift orchestra
Almat Productions
Eli Krantzberg
Almat Productions
Old 02-03-2001, 08:21 PM
toecat toecat is offline
Ed,
Thanks for the information. I have read alot of people using Logic with Pro Tools your the first that has made it understandable. I really think the bottom line is getting my music record, it does not matter if it is Pro Tools, Logic or whatever. The right tool for the right job.
Thanks
Toecat
Old 02-04-2001, 12:35 AM
Default Hello Logic users.......Please explain about Logic Midi
I am starting to find the limits of the Pro Tools Midi. Could anyone who uses Logic explain how the midi is better. I see you get unlimited midi tracks with logic, does that mean you can run two devices or more at the same time(ex. drum Machine and keyboard)?
It would be nice to edit the midi on both up until the final mix. Also can you break down the midi to were you can record on seperate tracks(ex. seperate drum tracks from a drum machine)? Can you record Audio onto Logic thur the Didi hardware and import tracks from Logic to Pro Tools? And last does the Logic AV have the same midi feature as the Gold?
Thanks
Toecat
Can anyone explain the logic in GROUPS? Terry Wetzel Pro Tools 9 10 03-22-2014 02:30 PM
Logic Pro users: Midi & audio between Logic & PT dtmprod Pro Tools TDM Systems (Mac) 4 09-24-2006 04:16 PM
Any ex Logic users? KimSira Pro Tools TDM Systems (Mac) 26 01-05-2006 02:21 PM
OT: Logic Users... Is logic Pro 6 buggy?? cliepe12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-13-2004 02:19 PM
Logic/001 Users - Do you use Logic only for sequencing? SHC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-07-2001 07:51 AM
