Old 10-03-2006, 12:49 AM
mseans mseans is offline
Default 1394 light on my Digi 002 Rack blinks and locks up
I'm having some frustration with my Digi 002 Rack. When I launch PTs, the 1394 light flashes at the point when my screen says DAE Loaded. At that point my system locks up until I shut down ProTools. It started intermittently last week and now it happens every time. I'm making a lot of progress lately on my writing and recording, so this has been really frustrating for me. Do you have any advise as to how I can get past this? Thanks a lot for all of your help.
Old 10-03-2006, 05:35 PM
absent absent is offline
Default Re: 1394 light on my Digi 002 Rack blinks and locks up
I'm curious about this as well because I've had the same thing happen. It was usually remedied by a restart.
Are you using an onboard firewire device or a PCI card?
If PCI card, which one?
I found this as a problem on a MAC that was diagnosed as a firewire conflict. It said to clear the firewire cache. I have no idea how to do this on a PC or if you even can. I ended up seperating my backup hard drive and my 002r one on the onboard and one on the PCI card and it seemed to go away.
Good luck!
Old 10-03-2006, 10:58 PM
Dogcode Dogcode is offline
You both have a problem with your power supply/power harness in your 002. Me, as well as many others have experienced this. Call digi and they will send you a new power harness and power supply.
....dog
PT 9
Control 24
003 Rack
Mac Pro 2.66 Quad
Adam A7
Waves Gold, VSeries
Pultec Bundle
URS, McDSP
Old 10-04-2006, 08:00 AM
What I'm describing is not the power harness issue. I experienced that a couple of years ago. What we're describing is a flashing 1394 light which I believe is due to some firewire conflict.
The way you know it's power harness is the 002r "resets" itself. it's easy to tell because it gives you the "clicks" when powering up and the mute is engaged.
Old 10-04-2006, 08:03 AM
dubhausdisco1 dubhausdisco1 is offline
Have you tried a different cable? There is not too much that can go wrong....
Old 10-04-2006, 08:12 AM
No.
It solved itself when I took the backup drive off the same 1394 controller.
Old 10-04-2006, 09:16 AM
Sometimes the 002 will get mad if you h ave switched video cards too... (just for future ref)
Old 10-12-2006, 03:06 PM
stevegalante stevegalante is offline
I'm having a similar problem with my Digi002Rack. When it powers up the mute red light is (obviously, but the 1394 green led is off. I can hear repeated 'clicks' as if the unit tried to connect to the firewire with no success. The mute remains on and there's nothing I can do. I tried different cables and a different computer (a Mac instead of a PC), same result. Is this a 002 hardware problem ?
http://www.stevegalante.com
Old 10-12-2006, 03:20 PM
spkguitar's Avatar
Yes, it is the infamous "Power Harness" problem. Contact Digidesign by phone, and they will ship the fix to you ASAP.
As a temporary workaround, unplug the unit, open it, and reseat the power harness.
Digi 002 Rack: Firewire Link Lost - no 1394 light PacoPoblano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-03-2016 08:05 PM
1394 Light Blinks In Win7/64, But Not XP? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-27-2010 02:49 AM
xp32 bit 1394 Light Blinks goes away freeze at DAE SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 04-16-2010 11:40 AM
Is My Digi 003 Rack Fried? 1394 Light Out lpeckham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-09-2010 05:10 PM
1394 led light blinks on 002 Irenaus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-18-2008 08:08 AM
