how do i send a 100% clean guitar?
so how do I send to my protools a 100% clean guitar sound and totally bypass all the 11 rack amps and effects .. I would like to sound to be just my guitar so I can use amplitube I cannot use reamp because I want to use the effects loop into amplitube... and I plan to record it
Re: how do i send a 100% clean guitar?
Are you using the 11R as your audio interface? If so, then just create a new mono audio track and select Guitar In as the input source. This will contain the unprocessed guitar signal.
Next question may be "Why is the guitar signal so low?" Check the manual or search past threads.
[SIZE="2"][COLOR="Blue"]Intel Haswell-E Processors 3.3GHz Core i7-5820K 6-Core; Memory - DDR4: 16GB DDR4-2400 Quad Channel (4 x 4GB); Primary Drive (OS): 240GB SSD SATA3; Secondary Drive (Audio): 2TB 7200 rpm SATA2; Graphic Card: 1GB (HD5450) Dual Display Graphics Card; Optical Drive: 22x CD/DVD Dual Layer Burner; Windows 10 64-bit; PT 12.5; Studio One Pro 3.2; Cubase Pro 8.5; REAPER; MixBus 3 |
if you use guitar in you get the processed signal...unless you go to the 11r and tell it to reamp.... but then you do not get the fx loop
thank you for the reply Last edited by ddropski; 02-24-2016 at 06:35 AM. |
How to get a decent sounding clean guitar? | Kinh | Eleven Rack | 9 | 03-05-2015 09:43 PM |
record / mix clean electric guitar | gianmetalbass | Tips & Tricks | 11 | 07-30-2013 01:41 PM |
Clean Guitar Tone running direct | KarNaL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-09-2007 09:16 AM |
Clean Guitar | rikttt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-12-2006 09:47 AM |
pops (clean guitar only!) | duanebonney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-22-2002 08:34 AM |
