#41
Re: Done.
#1 There are no Eucon "bandwidth" issues. Eucon uses a tiny percentage of ethernet bandwidth. It's a non-issue. #2 Switches don't have a problem with packet "collisions" - that's a problem with hubs. If you really understood the difference, you would not be using the term collision at all, it confuses people. From your *wrong* description of ethernet, it's this touchy-sensitive thing that can easily get screwed up because people are shopping online or streaming video on the same segment. Give me a break. #3 Ethernet is plenty fast and "real time" enough for this application. Everything has some latency. At < 10ms that is perfectly adequate for the extremely basic task of moving a fader or updating a display. It's just little text data. Saying that it has to be *perfectly* real-time is another crock of nonsense. Quit confusing people. Eucon definitely has some problems but your advice for folks to unnecessarily complicate their setups isn't going to fix them. |
#42
Re: Done.
Yes, Bill. As I said standards are in place for a reason. I was simply reiterating that using a public IP on a local network doesn't necessarily mean it is accessible by the outside world.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
#43
Re: Done.
Well the only thing I could see where having latency issues could be a problem is with writing automations but then again <10 milliseconds is not a lot.
#44
Re: Done.
It's definitely a far cry from what this guy is trying to peddle. I get between 1 and 3 ms pings via wireless, <1 ms on wired. 10 would be a rather high, extreme case.
#45
Re: Done.
I had many issues with my artist mix and controls. uninstaling eucon, repairing authorizations, rebooting, reinstsalling, rebooting definitly fixed everything.
www.tristanklein.com |
#46
Re: Done.
There is nothing at all "bad" about the information I have provided. By following the instructions I provided, folks will end up with a technically correct setup. That is what most users here want. I am not confusing anyone...it is you who are confusing people by claiming my advice is "bad" without providing even one piece of refutation of my recommendations! One advantage of being old is that I have seen a lot of things come and go in IT. On my first IT job my computer had a 5 MB hard disk. Nobody thought we'd ever be able to fill it up. But, later this week I will be adding two more 1 TB drives to my music computer. I remember when I had 100 users on a 10 Mb/s network, and traffic was barely even a "blip". And less than two years later the network was getting saturated. On a network with <10 users carrying both Internet and Eucon traffic suffer from bandwidth issues today? Probably not. But what about two years from now? On a network with <10 users carrying only Eucon traffic ever suffer from bandwidth issues due to heavy Internet traffic? No. Since there is no Internet traffic on the Eucon network an increase in Internet traffic will have absolutely zero effect on the Eucon network. Were it going to cost $100,000 to create a separate Eucon network, I would probably say, "Don't bother". But since creating a separate Eucon network will cost <$100 and will guarantee that one will never suffer from bandwidth issues due to non-Eucon traffic, that is what I recommend. If you have what you believe to be "good" information that refutes my information please post it...I have no problem with saying I'm wrong about something and learning what is correct. But until you can refute what I have posted, may I suggest you stay out of this conversation, as it is you who is creating confusion here...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
#47
Re: Done.
IMO, cheap switches (and even sometimes USB hubs etc) are often better as the expensive ones often have extra *features* (IE firewallish stuff etc) that are not needed and sometimes conflict. Also I always keep cloned boot disks so once you troubleshoot and get it all up and running you can always go back to a safe place if you need to. I like carbon copy cloner and a naked usb drive dock. I see the wisdom of bill's approach is it's simplicity, but sometimes the *other* simple is more *simple*. IE having the possibility of a computer connecting to 2 different networks simultaneously can be a mess too. I have had good luck setting my units fixed to 192.168.1.(252-255), this way they aren't fighting for IP's with any DHCP. Lol at whoever said that "if a PoE cam is easy"...my experience is getting anything really running perfect on a network can be finicky (you might get lucky!), PoE cam's definitely included. |
#48
Re: Done.
It is NOT. NECESSARY. to separate Eucon from the rest of the network. Quote:
I'm not going to ramble on about hard drives and other nonsense. Suffice it to say that I have nearly two decades of experience in corporate IT, dealing with matters way more complicated than this. Keep it simple, stupid. Quote:
The current problems with Eucon right now have *NOTHING* to do with lack of bandwidth. |
#49
Re: Done.
And when I brought up PoE cameras I was referring to the fact that they work reliably without the nonsense ethernet bottlenecks like packet collisions that he thinks are still a serious factor 30 years later. |
#50
Re: Done.
You guys are way more advanced with network stuff than I, just had to laugh when I saw that because I had a hell of time getting a little PoE cam to work for my wife. I'm sure the problem there was something else entirely...but point being any networked stuff can either just work and be easy or it can be a lot harder than you'd hoped. |
