Old 04-30-2020, 12:06 PM
Mattafact Mattafact is offline
Default Dual Boot Cheesegrader Mac Pro with PT 10 HD and Ultimate
I just bought PT 10 and plan to use it on Snow Leopard or Mountain Lion. My license also comes with Ultimate 2020.
For Ultimate I was planning on running High Sierra or Mohave. In that instance, can I use the optical port on my mac pro to feed something like an Apogee Rosetta 200 or 800? They're cheaper than buying an HD Native card and I wouldn't have to ditch my HD cards for tracking.
HDX, Mac Studio, Rupert Neve 511 x 9, Rupert Neve 551 x 8, Manley Variable Mu, Massive Passive, Stereo Pultec, ELOP, VoxBox, and DVC, DBX 160s, Daking Fet III, Distressors, M905 Monitor Controller and other cool stuff.
Old 04-30-2020, 01:22 PM
s.d. finley s.d. finley is offline
Default Re: Dual Boot Cheesegrader Mac Pro with PT 10 HD and Ultimate
I would go with Mountain Lion as it can access more RAM. Which Mac Pro version do you have? This all should work too BTW. I have a MP 3.1 with mountain lion and El crap on it separate HDs. Works great!!
sdf
www.sugarhillstudios713.com
Old 04-30-2020, 06:02 PM
That's good to know about the ram. Thanks for the info. I have a 12 core 5,1.
Old 04-30-2020, 08:27 PM
Ben Jenssen's Avatar
Not correct. ML can access lots of RAM, problem is PT10 can't access more than 4gb, being a 32bit app.
Edit: I meant even earlier versions than ML can access more ram.
Old 05-01-2020, 06:58 AM
Can I use Ultimate with the optical out into a Rosetta's adat input for mixing?
Old 05-01-2020, 10:31 AM
https://lowendmac.com/2018/mac-pro-21-64gb-of-ram/
this also works with Mac Pro 3.1 for the OP with a 5.1 this won't make a difference as his MP shipped with a higher OS than ML . Earlier versions of Mac OS cannot access more RAM as the older OS was not 64 bit.
sdf
Old 05-01-2020, 01:22 PM
The Mac optical out is not ADAT format, it is optical SPDIF/TosLink. I'm not that familiar with the Rosetta, but unless the Optical port on the Rosetta can do stereo SPDIF/TosLink, then probably not.
Scott Gatteño
Old 05-05-2020, 04:36 AM
notable's Avatar
notable notable is offline
I use the optical port on my cheese grater with the apogee mini-dac to go to a pair of powered monitors (and headphones) and it sounds great. A great sounding core audio out option.
Notable.com
AfricanUnderground.com
DemocracyinDakar.com
NomadicWax.com
Old 05-05-2020, 06:04 AM
JFreak's Avatar
JFreak JFreak is offline
As already mentioned, Mac optical output is SPDIF. Rosetta 200 (stereo box) can do SPDIF optical but Rosetta 800 (8-channel box) can only do ADAT/SMUX
Janne
Old 05-06-2020, 10:50 AM
Good to know. Thanks!
OT: PT-Win 7 / XP Dual-Boot; Question re: Win 7 Install, Boot Manager Files taylor4814 Windows 1 02-16-2012 05:54 PM
Boot Camp - Dual Boot, Dual Versions of PT LE? bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-17-2009 04:15 AM
Help with Dual Boot on Dual 1 ghz QuickSilver new engineer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-13-2005 06:12 AM
New G4's are all Dual Boot BeachDog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-23-2003 02:00 PM
Configure Dual Boot on New dual 1.25?? cliepe12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-10-2003 04:45 AM
