Old 04-17-2014, 03:33 PM
Barry Johns Barry Johns is offline
Default MacPro1,1 64 Bit Hack and Processor Upgrade
I know there is a hack out there to fool Mountain Lion into seeing my Gen 1 MacPro to thinking its 64 bit capable. Do you think PTHD 11 will do the same?
I also just ordered replacement processors to take my computer to an 8 Core Machine. I also ordered a SSD drive that I plan to use for the system drive.
Do you think I can possibly run PTHD 11 on the machine after all that?
FYI, the mod takes my Geekbench scores from 5609 to over 11k.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 04-17-2014, 07:47 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: MacPro 1.1 64 Bit Hack and Processor Upgrade
I would say it's cheaper to get a real hack, then you will get real power.
Mine cost me $1500, but x58 chipsets can be had for much less
Daniel
Old 04-17-2014, 09:17 PM
The above cost me less than 400.00.
Old 04-17-2014, 09:22 PM
YYR123's Avatar
I understand but there is a point when you will get more for just a little more money.
Example 2008/2009 Mac Pro's would be much better scenario
Native 64 bit instruction set.
Daniel
Old 04-20-2014, 05:15 PM
Well I installed the new CPU's today. Went from. 2.66 quad core, to a 3.0 Eight Core. Was very, very easy and cost 200 bucks to double the speed of my computer.
Geek bench:
Before - 5069
After - 10,808
I also have an SSD 250gig to install, but waiting on the macpro caddy.
Very excited about this upgrade!!!
Old 04-20-2014, 06:51 PM
YYR123's Avatar
Nice
Daniel
Old 04-30-2014, 02:36 PM
Jeff E Jeff E is offline
Geek bench:
Before - 5069
After - 10,808
Barry,
I am in the exact same boat as you are or as you were. So can you run the latest Mac OS on your system now?
I too want to upgrade my PTHD system and think it would be cheaper to do what you are are doing. I figure if the case is the same and the drives are the same, why cant I just buy new guts?
SO, did the change make your system truely 64bit? Can you run maverics now?
Old 04-30-2014, 09:09 PM
Originally Posted by Jeff E View Post
Barry,
Jeff, I've not had time yet to give it a try. I need to buy a different Video card for the hack to work apparently. I have the original OSX installed on a spinning drive, and a second OSX on a SSD. So I think I'm gonna give it a try on the spinning drive once I buy a replacement video card.
Have you watched any of the videos about the hack yet?
PT10 & MacPro1,1 VRAM leaks? altavek macOS 0 02-02-2012 09:13 AM
Should I upgrade to this Processor!! HELP Pro Tools LE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-15-2007 12:32 PM
Processor Upgrade bjackson35 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-28-2006 08:37 AM
OWC processor upgrade and PT6 Fritz Pro Tools TDM Systems (Mac) 9 06-07-2004 07:27 AM
upgrade processor outfit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-16-2003 09:14 AM
