Re: Mbox 3 Mini drivers for El Capitan?
I just found updated drivers for the MBox mini 3 :
http://cdn.avid.com/AudioDrivers/Mac..._OSX_1.3.1.dmg So far, it looks good on El Capitan !! I guess it will be announced shortly... |
Great!
FYI- The v1.3.1 driver was added late last night and the Mbox Mini Drivers page has been updated.
• linkedin •
Thanks |
Hey guys just downloaded and installed the driver update 1.3.1 and no luck, still seeing hardware not connected. I'm all out of ideas
someone please help |
#16
Had one similar report (with the Eleven Rack Driver) but I can't repro with any combination of install/uninstall with old and new drivers on 10.11.2. Just sent a request off for file details to help you uninstall manually.
• linkedin •
#17
Can you confirm the driver version and the status in the Mbox Mini control panel?
• linkedin •
#18
Re: Mbox 3 Mini drivers for El Capitan? (Interface not recognized)
well it says package 1.3.1
I was not able to uninstall 1.3 as it was giving me an error, maybe the issue is that I installed the new drive over top of the old one? how would I manually uninstall both 1.3 and 1.3.1 so I can try and do a fresh install? |
#19
FWIW - Mine is working just fine with the new drivers. If it helps, I had previously uninstalled 1.3 using the procedures in this thread.
http://duc.avid.com/showthread.php?t=375575 Good luck! |
#20
So, check this. I followed some instructions from another thread and uninstalled the previous and current drivers.
Restarted and checked to see that Avid Mbox Mini was NOT in the audio settings menu. Confirmed. Re-installed 1.3.1 The Mbox Mini control panel still doesn't recognize the Mbox Mini and shows a "Driver Interface Process" error BUT The Avid Mbox Mini is present in the Audio Settings Menu and in Pro Tools. I selected it as the playback engine and it works great. So, It's not working... but it is. Last edited by ShredSavage; 01-18-2016 at 11:02 AM. |
El Capitan and Mbox 2 Drivers. | thegame15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 26 | 11-26-2016 04:26 PM |
Mbox 3 and El Capitan drivers | MarcelMendesFilho | FireWire & USB Audio Interfaces (Mac) | 34 | 02-12-2016 06:25 AM |
Mbox Pro 3 not recognized by PT12 on El Capitan | sorryguitarist | FireWire & USB Audio Interfaces (Mac) | 5 | 01-16-2016 07:28 AM |
El Capitan updates for C400, C600, Eleven Rack, Mbox, Mbox Mini, Quartet | Avid | Technical Alerts | 0 | 01-14-2016 07:28 PM |
Mbox Mini 3rd Gen not appeari as Playback Engine option in Protools 12.3.1 El Capitan | zhurry | Pro Tools 12 | 9 | 12-12-2015 08:55 PM |
