Old 06-06-2018, 11:37 PM
o-matic o-matic is offline
Default Re: 18.3 update - EQ for Cubase users
I restarted it several times and uninstalled it as well. The fader modules are off. Did you have the little danger sign next to the WSConnect icon too, Eddie ?
No real help from Avid support except the suggestion of re-installing the Eucon workstation package...
Old 06-07-2018, 04:46 AM
Believe it or not, this morning I wanted to try to re-install the 18.3 update, just in case, and the S6 was back to normal : WS Connect has been loaded on my 2 workstations without complaining about version mismatch, the console loaded up nicely, the faders are effective... It’s like nothing happened.
I can not say much more about it as I didn’t do anything since yesterday and my 25 or so reboots and 2 Eucon uninstall.
Maybe the S6 needed to be a few minutes switched off... Or to sleep on it !
If you know what happened, I’d be happy to know.
Old 06-07-2018, 04:48 AM
Avid support was about to ask for a remote session during the day. A bit comforting.
Old 06-07-2018, 07:48 PM
EddieJones's Avatar
Glad it's working now though ;-) let me know if this happens again but I'm thinking this issues is to do with the installer so hopefully gone for good.
Old 06-08-2018, 12:03 AM
Hey Eddie. I was about to create another thread because the problem happened again after a restart of the mac.
With the same error message : mismatch version.
The WSControl is initializing the network connections for 2 minutes, then the logo stops but the beach ball starts its looong spinning...
We’ve checked the setup with the support of my reseller and it looks like everything is well configured. Every module is running the right version 4.0.7 244...
Old 06-08-2018, 12:06 PM
creativecontrol's Avatar
Greetings,
Is EuControl (any version) running on the subnet? Are any other versions of WScontrol running on the subnet?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-15-2018, 12:50 AM
Hey Jeff.
I'm sorry I'm not familiar with the meaning of 'subnet'...
But, the S6 works after I disable the firewall. No firewall ? Is it what you suggest for a normal configuration ?
Can you please answer my last question about the Fabfilter EQ ?
Is there a specific way to access the dedicated EQ view (magenta) on Cubase ? On Cubase, "EQ" on the process module refers to the internal EQ section. For third-party plugs, I usually press "ins"...
Old 06-15-2018, 12:13 PM
Greetings,
I would recommend in the future trying to keep each individual thread here on topic. This one has gotten a bit fragmented. I was under the impression initially in the conversation that we were discussing EQ vs Insert parameter access in Pro Tools including Fabfilter Pro-Q2. I don't believe you can access anything but the built in EQ in Cubase (same in Logic) in the magenta mode.
A subnet is short for a subnetwork which is:
https://searchnetworking.techtarget....inition/subnet
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-15-2018, 09:42 PM
EddieJones's Avatar
Originally Posted by o-matic View Post
Hey Jeff.
When installing the S6 Software (WSControl) it would have asked you to allow it through the firewall. It sounds like this didn't happen. I would not recommend running with the firewall turned off permanently.
If you are on a Mac here's some info about manually allowing it. OSX Firewall settings
Old 06-17-2018, 01:07 PM
Thanks, guys.
Attention Cubase/Nuendo users J-S-Q Avid S1, S3, Dock and Control App 0 04-27-2015 06:57 AM
Attention Cubase/Nuendo users J-S-Q Artist Series 0 04-27-2015 06:23 AM
HOW MANY PRO TOOLS USERS VS CUBASE VS LOGIC VS DP? Johnny916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 05-05-2004 07:07 AM
Any Ex-Cubase Users? Your Stories Please... Joel Kanning 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 02-24-2003 02:16 PM
