Old 12-17-2014, 11:52 AM
JacksonRR1 JacksonRR1 is offline
Default Issues with Eleven Rack and PT 11
Hi Everyone,
I upgraded to Pro Tools 11 last week, and everything appeared to working fine. Today I went in to record a guitar track using my Eleven Rack, and experienced an issue.
Normally, when I start up Pro Tools, no guitar playback from the 11R will be audible unless I arm one of the tracks where the 11R is set as the input. However, in Pro Tools 11, when I start up the program, I can still hear guitar playback even if no tracks are armed for recording. The odd thing is that at this point audio is only coming out of my left monitor, or left headphone speaker. If I do set a track to be armed for recording (one that is panned 100% right for example), I still hear the playback through the left monitor, but also hear the record armed track through the right monitor. The most annoying part of this is that when I do begin recording, I can hear playback from both Left & right, when it should be panned 100% right.
If I launch PT 10 instead of 11, everything functions normally where I don't hear any Eleven Rack guitar playback unless the track is armed for recording.
Anyone else experience this, or any ideas how to fix this?
Old 12-17-2014, 12:08 PM
Default Re: Issues with Eleven Rack and PT 11
What is the playback engine set to in Pro Tools 11?
It needs to be "Eleven Rack" not say "Aggregate Audio" or anything else.
Try defaulting all input, output and bus IO. Go to Setup>IO and click default on each page.
Reboot the computer, try again.
Try trashing prefs and try starting with a new empty session.
What exact computer (hopefully not really a Core 2 Duo... but even if it is that is not necessarily the issue) , OS X and driver version? etc. etc. start at the "Help us Help You - READ THIS Before Posting!" link above on this DUC page.
And Pro Tools 10 and 11 coinstalled... likely not the issue, but for other reasons hopefully you have carefully followed the coinstall instructions/requirements.
Old 12-17-2014, 08:16 PM
Thanks for the reply Darryl.
The playback engine is set to Eleven Rack. I had tried defaulting the input, output and bus IO's, and had rebooted but the problem was still there.
After trashing prefs, I tried again and it is now working correctly in both PT 10 & PT 11.
And the system info I had on my profile was not accurate. I'm now using a Windows laptop with a Core i5 & 8GB of RAM.
Thanks for the tips.
Old 01-02-2015, 12:21 PM
So this issue has returned today, and I can't seem to fix it.
Since I last posted, I have completely uninstalled PT 10 from my system, as any plugins I use are AAX, and since I thought I had this issue taken care of, there was no need for PT 10 anymore. It worked fine for a few days, and now back to the exact same symptoms I described in the original post. Here's what I have done so far:
Defaulted I/O's - no change
Trashed Prefs & Rebooted - no change
Tried multiple different sessions & a brand new session - no change.
Uninstalled PT 11 & Uninstalled 11R Driver
Installed 11R Driver Version 1.1.9
Installed PT 11.3 - no change
Created a new Windows User ID - no change
SiSoftware Sandra
ID
Host Name : LENOVO
Workgroup : WORKGROUP
Computer
Model : Lenovo 62775AU ThinkPad Edge E431
Serial Number : PF0****
Chassis : Lenovo Notebook
Mainboard : Lenovo 62775AU
Serial Number : 1ZSGN******
BIOS : Lenovo HEET34WW (1.15 ) 07/02/2013
Total Memory : 7.6GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz (2C 4T 3GHz/3.2GHz, 3GHz IMC, 2x 256kB L2, 3MB L3)
Socket/Slot : FC PGA988 (G2)
Chipset
Memory Controller : Lenovo Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.6GHz 128-bit, Integrated Graphics
Memory Module(s)
Memory Module : G.Skill F3-12800CL9-4GBSK 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (9-9-9-27 5-39-12-6)
Memory Module : Hynix (Hyundai) HMT451S6AFR8A-PB 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : Lenovo ThinkPad Display 1366x768 (1366x768, LP140WH2-TLT1, 13.9")
Video Adapter : Intel(R) HD Graphics 4000 (16CU 128SP SM5.0 350MHz/1.1GHz, 64MB DDR3 1.6GHz 128-bit, Integrated Graphics)
Graphics Processor
OpenCL GP Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.1GHz, 1.6GB DDR3 1.6GHz 128-bit, Integrated Graphics)
Compute Shader Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.1GHz, 64MB DDR3 1.6GHz 128-bit, Integrated Graphics)
Storage Devices
HGST HTS725050A7E630 (500.1GB, SATA600, 2.5", 7200rpm, 32MB Cache) : 466GB (C:) (Q:)
HL-DT-ST DVDRAM GU70N (SATA150, DVD+-RW, CD-RW, 512kB Cache) : N/A (D:)
Logical Storage Devices
SYSTEM_DRV : 1GB (NTFS)
OS (C:) : 451GB (NTFS) @ HGST HTS725050A7E630 (500.1GB, SATA600, 2.5", 7200rpm, 32MB Cache)
Recovery (Q:) : 14GB (NTFS) @ HGST HTS725050A7E630 (500.1GB, SATA600, 2.5", 7200rpm, 32MB Cache)
Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GU70N (SATA150, DVD+-RW, CD-RW, 512kB Cache)
Peripherals
LPC Hub Controller 1 : Lenovo Panther Point LPC Controller
Audio Device : Lenovo Panther Point High Definition Audio Controller
Audio Codec : Conexant 506E
Disk Controller : Lenovo Panther Point Mobile 6 port SATA AHCI Controller
USB Controller 1 : Lenovo Panther Point USB xHCI Host Controller
USB Controller 2 : Lenovo Panther Point USB Enhanced Host Controller #2
USB Controller 3 : Lenovo Panther Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : WebEx Document Loader (1200x1200, Colour)
Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour)
Printer : Nitro PDF Driver 8 (600x600, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Brother HL-2140 series (1200x1200)
Network Services
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet)
Wireless Adapter : Intel(R) Centrino(R) Wireless-N 2230 (802.11n (HT), AES-CCMP, 144Mbps)
Power Management
Battery No 1 : LGC 45N1049 49.84Wh/4.11Ah
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Old 01-02-2015, 07:43 PM
Does the Eleven Rack show up as the playback engine and work Ok when you just play back audio though it?
if so I would try a reinstall of Pro Tools 11. If that does not fix it reinstall Windows and all the apps etc.
If not I'd suspect the USB cable, USB port, driver or hardware.
Old 01-02-2015, 07:59 PM
Eleven Rack does show up as the playback engine, and everything sounds fine when playing back audio. When recording it also records fine, its just that the signal from the 11R will always be coming through the left channel while recording in addition to however it is panned in PT. The actual recorded signal is panned as it should be when played back after recording.
I've already uninstalled and reinstalled PT Eleven and the driver. I can try a different USB cable though.
Out of curiosity, I just uninstalled PT 11 completely along with the 11R driver, and then installed PT 10 and installed the 11R Driver 1.1.9. Everything works fine in PT10. As soon as PT starts, there is no audio coming through from the 11R unless I arm a track for recording, and it follows the panning correctly. It seems the issue is isolated to PT 11 with my environment.
Old 01-05-2015, 05:22 PM
Just an update on this issue for anyone that may find this thread in the future.
Per Avid support, this issue is a known issue with Pro Tools 11 when using Windows and an Eleven Rack. I still do find it strange that everything worked fine for a few days before the issue presented itself, but it is what it is. Looks like I'll be forced to use Pro Tools 10 on my Windows system until this issue is fixed.
Anyone else have this issue when using Eleven Rack to record in PT 11 on a Windows system? Avid suggested the workaround to this was to enable Low Latency Monitoring, but this was already enabled on my system.
Old 01-06-2015, 08:35 PM
Fezzler Fezzler is offline
So is it a done deal that every 11R and PT11 user will suffer from this?
[SIZE="2"][COLOR="Blue"]Intel Haswell-E Processors 3.3GHz Core i7-5820K 6-Core; Memory - DDR4: 16GB DDR4-2400 Quad Channel (4 x 4GB); Primary Drive (OS): 240GB SSD SATA3; Secondary Drive (Audio): 2TB 7200 rpm SATA2; Graphic Card: 1GB (HD5450) Dual Display Graphics Card; Optical Drive: 22x CD/DVD Dual Layer Burner; Windows 10 64-bit; PT 12.5; Studio One Pro 3.2; Cubase Pro 8.5; REAPER; MixBus 3
Old 01-06-2015, 08:55 PM
That's Avid's position at this point. Apparently the issue is unique to the Windows platform though, so if you have a Mac, hopefully the issue isn't occurring.
They have cited this knowledge base article as the issue I am experiencing: http://avid.force.com/pkb/articles/e...n-Pro-Tools-11
They also acknowledged that this issue can come and go intermittently without apparent cause. The issue has been known to Avid since at least July 1, 2013 (that's when the article was last updated). My hopes aren't high that it will be addressed anytime soon. I'm also concerned if they can't be bothered to fix such a glaring issue with one of their own interfaces if they will even be supporting the 11R with the next version(s) of PT.
I probably wouldn't have upgraded to PT 11 had I found this before upgrading. I did double check the system requirements and the interface requirements before deciding to upgrade. Shame on me for assuming that a Pro Tools 11 Approved interface would work properly. I would think an issue of this significance would at least warrant a note (something to the effect of "this is approved, but you can't monitor tracks properly when recording") on this page: http://avid.force.com/pkb/articles/e...nd-Peripherals
Old 01-07-2015, 08:58 AM
Benoni's Avatar
Benoni Benoni is offline
I have documented this issue here with a work around that works 99% of the time for me. If it does not work the first time, turn off everything and restart and try again.
Eleven Rack - Input Always Active/Doubling in Pro Tools
https://www.youtube.com/watch?v=TbRnyt6PVjc
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Protools HDX and Eleven Rack Issues [email protected] Eleven Rack 5 08-06-2014 09:09 AM
Eleven Rack Editor Issues jerry g Eleven Rack 2 04-23-2014 11:43 AM
Eleven Rack communication issues under OSX 10.9 lbar11 Eleven Rack 25 01-03-2014 04:37 PM
Eleven Rack FW 1.0.3 issues forum TheChimp Eleven Rack 43 12-02-2012 12:19 AM
Issues with Eleven Rack. Again. BrandonFrisby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-29-2010 03:30 PM
