Old 04-10-2019, 01:55 AM
priorytools priorytools is offline
Default Import Plugin Settings From Pro Tools ?
So if I have a mix set up of a live recording in Pro Tools on S6 in the studio, what is the best way to get this into S6L ?
Any help much appreciated.
Ta.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 04-10-2019, 08:04 AM
emluper emluper is offline
Default Re: Import Plugin Settings From Pro Tools ?
Save all your plug-in settings from the session to a new folder (maybe labeled S6L?) and then drag that folder to a USB drive. Plug the drive into a control surface and then exit out to the Windows desktop (Click the Options page, then the System Tab and hold Control while clicking on Quit). Once you're on the Desktop go to the C drive and find the plugin folder and drop your presets into the appropriate folders.
Old 04-13-2019, 03:32 PM
Thanks
Is there any way to import a pic of analog gear settings into Pro Tools! SomeOtherGuy Pro Tools 12 3 12-22-2015 04:13 PM
Do not import I/O settings ChrisMac macOS 10 11-12-2012 01:11 PM
Import session data, plugin settings preset name crizdee Pro Tools TDM Systems (Mac) 0 08-02-2011 07:37 AM
Import mix settings Alex_C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-21-2008 12:33 PM
Pro Tools 6 Plugin settings on PT 7 lkny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-10-2007 01:45 PM
