Old 06-06-2018, 02:36 AM
nigel smith nigel smith is offline
Default Pro Tools to Dolby CP750 via ?
Hi
We are configuring a screening/mixing room for use with Pro Tools and Media Composer.
Is there any sound quality advantage to using a Avid Omni interface, rather than the BMD Ultrastudio 4K SDI/HDMI audio output and de-embedder,
to connect to a Dolby CP750?
The CP750 is being used to balance/EQ 5.1/7.1 speakers for the space.
Thanks for any advice
Nigel
Pro Tools HD Native 10.3.7 on Nehalem 2.8 Quad core with 16Gb RAM.
Old 06-06-2018, 10:30 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Re: Pro Tools to Dolby CP750 via ?
Originally Posted by nigel smith View Post
Hi
Nigel
I output my HD I/O analog out to CP750 analog in (because I have xMon in the chain).
I also have CP750 AES in connected to AES out on HD I/O and to me ears it sounds a bit worse.
If you already have an Omni interface I wouldn't deal with the video card audio output and external de-embedders, because you will have less control and unpredictability especially with the BM drivers.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 06-06-2018, 09:06 PM
critictalk critictalk is offline
Better to ask an Dolby guy to do alignment of your room.
Old 06-07-2018, 01:26 AM
Thanks - The CP750 will be setup and aligned for the space by experts.
If I understand correctly Michael, you prefer the processing of the sound created by your Avid D/A and Dolby A/D to the clean digital signal?
I take your point about BMD drivers and de-embedding, but that's the approach we need for MC [doesn't support 2 h/w devices at once] and I'm trying to avoid too many signal paths for switching purposes.
Nigel
Old 06-07-2018, 01:56 AM
mgoorevich's Avatar
Nigel
Yes, I prefer the sound of the Avid D/A going into analogue d-sub input on CP750. Even though its a double conversion, the CP750 processing, sounds better for me that way.
You still can have the AES input for your MC output on BM card. And you just toggling the button in order to switch between AES and Analogue input.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
HTML code is On
Neyrinck Broadcast Supreme Bundle: Dolby E, Dolby Digital & Pro Logic John McDaniel Buy & Sell 1 10-20-2014 06:39 AM
Dolby CP750 Reckless Erik Post - Surround - Video 4 09-04-2013 12:35 AM
Dolby Media Producer Suite vs. Dolby LM100 TylerJohnson Post - Surround - Video 4 06-04-2012 02:41 PM
DTS, Dolby Digital and Dolby E with Paul Neyrinck Brent_Sydney Post - Surround - Video 4 05-08-2009 04:32 PM
Dolby E and Dolby Media Meter Newbie Questions AudioPostChris Post - Surround - Video 4 02-08-2009 03:53 PM
